976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 11, 2026, 11:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bit of stem refurb
Author Topic: bit of stem refurb  (Read 2496 times)
neiljonarcus
bit of stem refurb
« on: January 09, 2010, 10:33 AM »
sort of moved away from high mirror polishing and doing a bit of machined affect finish , moanjam ask me to refurb a mark 1 tuff neck stem
and a old goose stem
BEFORE TUFF NECK STEM
AFTER TUFF NECK STEM
« Last Edit: January 09, 2010, 10:58 AM by n2cus »
Offline Del
  • Re-living my youth!
Re: bit of stem refurb
« Reply #1 on: January 09, 2010, 10:37 AM »
better than polishing them in my opinion... nice one Neil
« Reply #2 on: January 09, 2010, 10:40 AM »
 :shocked: awesome finish that  :daumenhoch:
Deano
« Reply #3 on: January 09, 2010, 11:10 AM »
That is a real nice finish mate 8)
I like a good shine ;D and  the brushed finish is bang on.
Just goes to show you sure know how to work with metals as well as paint too :daumenhoch:
neiljonarcus
« Reply #4 on: January 09, 2010, 11:32 AM »
MONGOOSE BEFORE
MONGOOSE AFTER
« Reply #5 on: January 09, 2010, 11:37 AM »
thats nice, so how do you get the brushed finish?
« Reply #6 on: January 09, 2010, 11:44 AM »
Looking good there Neil  :daumenhoch:
Both have come up a treat  ;).
neiljonarcus
« Reply #7 on: January 09, 2010, 11:47 AM »
and that pro neck stem i have redone the bolts by taking the oxegen out of the metal , my friend has a kit  "its amazing how it works "
« Last Edit: January 09, 2010, 11:54 AM by n2cus »
moanjam
« Reply #8 on: January 09, 2010, 12:39 PM »
lookin nice mate cheers  ;) , will pop round for sexual favours later  :-*
« Reply #9 on: January 09, 2010, 01:30 PM »
Wow!  That Tuf-Neck has come up the dogs danglys  :daumenhoch:  What sort of kit did he use to clean them up?
« Reply #10 on: January 09, 2010, 01:44 PM »
i presume he has just used wet-n-dry sanding using a block, going through the grades until you get the desired finish...
am i right nelly?  am i? eh!   8)
neiljonarcus
« Reply #11 on: January 09, 2010, 06:44 PM »
i will take a photo of the kit i used
« Reply #12 on: January 09, 2010, 06:47 PM »
I agree  8)
ozone
« Reply #13 on: January 09, 2010, 09:50 PM »
The finish is lovely but the 1st pic of the restored sq corner stem shows the top cap has less of a curve than the base.
If you kept the cap bolted to the base then machined the front and sides prior to polishing/brushing, you would get a perfect match top and bottom and less (or no) curve. :daumenhoch:
That's how to achieve the pukka Tuff Neck squareness. ;D
Nice work all the same. ;)
