fixing skyway alloy hub (concaved in)
Steve P:
I used a large spacer that sat neatly on the rivet heads ... with a decent size bolt it pulled the hub out perfectly :daumenhoch:
firebird4130:
not had much luck with this, I tried knocking it out but it's not budging, I'm worried I'll crack the alloy if I smash it too hard ?
Bigfrawg:
--- Quote from: Steve P on February 10, 2010, 10:56 PM ---I used a large spacer that sat neatly on the rivet heads ... with a decent size bolt it pulled the hub out perfectly :daumenhoch:
--- End quote ---
this method is more effective especially if you are worried about smashing fook out of the hub :daumenhoch:
moanjam:
how do you get the bolt to attach to the hub ?
firebird4130:
that does sound safer, have you got a pic/illustration
Cheers :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
