976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 05:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  9/16 thread size tap needed
Author Topic: 9/16 thread size tap needed  (Read 3035 times)
trasher
« on: March 02, 2010, 08:17 PM »
heres my problem ,,,,,i got some nos painted bullseye cranks ,,
im going to get them striped and chromed ,,,so i thought id try some pedals on them first ,the threads are tight as a nuns c4nt
there was paint finish in the threads so i paint striped the threads ,,,i tried some skyway pedals in them ,,no joy ,,,,some repo hutch pedals ,no joy
some xcII's,, no joy ,,they seem to go in a couple of mm but totally tighten up
some cheapo vectors ,,,bingo ,,but i dont want to fit these into them ,,,but the maxycross cranks these came out of also take the other pedals i tried in the bullseyes   :-\
so the point im trying to get to is ,,,are there different types of 9'16 threads ie 26tpi,,unc,,bsf  :-\
im thinking of re taping them  :P
Re: 9/16 thread size tap needed
« Reply #1 on: March 02, 2010, 08:19 PM »
helicoil them
trasher
« Reply #2 on: March 02, 2010, 08:22 PM »
helicoil them
arn't helicoils ,for when the threads are fooked ,,,,
Offline Gary72
« Reply #3 on: March 02, 2010, 08:25 PM »
helicoil them
Dont think you would get away with it. Unless you wanted to use 1/2 pedals. When I've used helicoils in the past you have to make the hole bigger to accept the coil. So you would probably have to drill out the original thread to re-cut a new thread for the coil.
I would try running a tap down the thread. Although a left handed tap might be difficult to track down.
« Reply #4 on: March 02, 2010, 08:28 PM »
my miss reading  i thought they was pooped  a bike company in kent sells all the taps you will need
cant find the name.
trasher
« Reply #5 on: March 02, 2010, 08:33 PM »
helicoil them
like these ,,,
http://cgi.ebay.co.uk/RDGTOOLS-9-16-UNC-TAPS-SPECIAL-LEFT-HAND-THREAD_W0QQitemZ370292234310QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET?hash=item5637231846
Offline HUTCHMAN
« Reply #6 on: March 02, 2010, 08:34 PM »
i think there's a thread in tech & resto stickies about a company that does all this kind of stuff.
Here we are..
http://www.radbmx.co.uk/forum/index.php'topic=52666.0
« Last Edit: March 02, 2010, 08:37 PM by HUTCHMAN »
trasher
« Reply #7 on: March 02, 2010, 08:38 PM »
what i really need to know is are they ,,,,bsw ,,,,,bsf,,,,28tpi ,,,,12tpi ,,,,,unc,,,,unf,,,,, :idiot2:
think i might just go down the local engineering shop ,,take the pedals i want to fit to them with the cranks  :coolsmiley:
snav69
« Reply #8 on: March 02, 2010, 08:39 PM »
Didn't some 3 piece cranks have 1/2" threads  ??? i know they weren't that common but do remember them  ;)
Have you tried an 1/2" pedal in them  :-\
 :coolsmiley:
Offline HUTCHMAN
« Reply #9 on: March 02, 2010, 08:42 PM »
 :coolsmiley:
CW,Maybe Anlun and Terry Cable??
trasher
« Reply #10 on: March 02, 2010, 08:46 PM »
 :coolsmiley:
tried that dude ...its like a wizards sleave  ;)
« Reply #11 on: March 02, 2010, 09:44 PM »
9/16" pedal taps are all the same thread 20tpi.  I have a set of pedal taps if you want to borrow them the gay pensioner.
trasher
« Reply #12 on: March 02, 2010, 09:49 PM »
now thats the answer i needed ,,cheers sean  :4_17_5:,,,,mate ill see what i can sort locally ,,if no joy ,ill give you a shout  :daumenhoch:
« Reply #13 on: March 02, 2010, 09:50 PM »
No worries mate, pm me if you want them and I will post them up to you.
trasher
« Reply #14 on: March 02, 2010, 09:57 PM »
top man  ;)
