976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 01:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  anyone running a PPP power disk on 3 piece cranks?
Author Topic: anyone running a PPP power disk on 3 piece cranks?  (Read 2732 times)
Glen
« on: March 05, 2010, 02:18 PM »
If you please get in touch!
Re: anyone running a PPP power disk on 3 piece cranks?
« Reply #1 on: March 05, 2010, 02:20 PM »
i will be as soon as its all bolted together glen :-\ why mate?
« Reply #2 on: March 05, 2010, 02:21 PM »
Running a PPP powerdisc and chainring with Cook Bros cranks on my Slingshot Glen.
Offline double chevron
« Reply #3 on: March 05, 2010, 02:34 PM »
Think you gotta remove the packet first mate  :LolLolLolLol:
« Reply #4 on: March 05, 2010, 02:35 PM »
« Reply #5 on: March 05, 2010, 02:37 PM »
im gonna have the same problem with mine glen  ??? will it cause that much of a problem when riding?
« Reply #6 on: March 05, 2010, 02:39 PM »
mmm im going to try a little bead of silicone i think, should stop any play in it?
« Reply #7 on: March 05, 2010, 02:43 PM »
Not sure that will stand up to riding but if it's a carpet queen should be all good  :daumenhoch:
« Reply #8 on: March 05, 2010, 02:49 PM »
fook what we gonna do then mate ???
moley
« Reply #9 on: March 05, 2010, 02:50 PM »
Try a cutting up  a tin can to make a shim or use tin foil to take up the excess around it.  So long as your makeshift shim can't pop out then it should keep it place as the the tophat shouldn't move in relation to the axle.     Just make sure the shim is around the entire tophat so that it keeps everything central and you should be fine (I hope...............no lawsuits if ya not)  ???
moley
« Reply #10 on: March 05, 2010, 02:54 PM »
Tin foil wrapped round with excess at the end that you fold over into the centre hole..
Insert into Sprocket and hammer it home and hopefully it will stay in place.  then cut away the excess tin foil.
If it works..............it'll be a miracle...........but its worth a try..............for a laff!!   :D
« Reply #11 on: March 05, 2010, 02:56 PM »
i doubt if you could get anything thin enough to make a shim tbo. what about a bead of no more nails? ???
moley
« Reply #12 on: March 05, 2010, 03:08 PM »
Tin foil is thin!!  :D
dj_benice
« Reply #13 on: March 05, 2010, 03:15 PM »
If you can get access to a lathe(sp) then making your own isn't very hard, even I managed it n I'm an office bod ;)
