976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 06:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing profile cranks
Author Topic: removing profile cranks  (Read 4159 times)
Offline boofy44
« on: March 08, 2010, 12:42 PM »
trying to get some removed and its doing my nut in,help please.
snav69
Re: removing profile cranks
« Reply #1 on: March 08, 2010, 12:43 PM »
have you got the proper tool  ???
If so, whats the problem  :-\
dan-dare
« Reply #2 on: March 08, 2010, 12:48 PM »
What tool?
Just remove a bolt, and tap the spindle through using a drift. :-\
Offline boofy44
« Reply #3 on: March 08, 2010, 12:52 PM »
i,ve got the tool you use to install them,do you use it to remove them as well?
snav69
« Reply #4 on: March 08, 2010, 12:55 PM »
Yes, remove the sleave off it then screw into place finger tight, then hit the head with a hammer  ;) , i use a rubber mallet  :daumenhoch:
THIRSTYKIRSTY
« Reply #5 on: March 08, 2010, 01:30 PM »
rob
if ya get stuck mate
give me a shout ,,,will do it for ya
rus
Offline boofy44
« Reply #6 on: March 08, 2010, 10:40 PM »
think the weekend had caught up with me.after screaming the street down i realised what i should be doing.can't
get the fooking bearings and cups out now.dont want to bray them out coz i'm selling them. :wtf:
« Reply #7 on: March 09, 2010, 01:13 PM »
i always use the screwdriver method......put it through and against the insode edge of the bearing cup, then tap gently going round and it should pop out  :daumenhoch:
moley
« Reply #8 on: March 09, 2010, 01:18 PM »
I use an extension bar off a socket set.
The nice square but rounded end is perfect for sitting against the bearing cup and smacking it out.
Makesure you grease the BB and new bearing cup to aid installation and removal in the future!!  :daumenhoch:
Offline boofy44
« Reply #9 on: March 09, 2010, 11:01 PM »
i soaked them overnight in wd40 and managed to get them out using the screwdriver method.
cheers fellas.
motomagII
« Reply #10 on: March 10, 2010, 08:44 AM »
this is howe i do it too  :daumenhoch:
motomagII
« Reply #11 on: March 10, 2010, 08:45 AM »
« Reply #12 on: March 10, 2010, 11:18 AM »
I Use A copper punch (Drift) as it acts as a sacrifial material leaving the bearings as they are meant to be!
Offline jT Racing
  • i like bikes. :/
« Reply #13 on: March 10, 2010, 11:14 PM »
 ;) that's the idea.
ding dong
Offline downlowmatt
« Reply #14 on: September 05, 2015, 11:54 AM »
So I've got a pair to remove. I've taken the arms off, do I just support the frame (on wood) and then drift the spindle out with a punch?!
Offline downlowmatt
« Reply #15 on: September 05, 2015, 11:55 AM »
Do I have to get the bearing out on one side first?
Offline john4130
« Reply #16 on: September 05, 2015, 01:45 PM »
the axle should just slide out with a bit of help from a hammer, then use the above method for removing the bearings and cups.
Offline nosepickben
« Reply #17 on: September 05, 2015, 03:28 PM »
Axle needs gently tapping out so you can get to remove the bearings.
  • Andy
« Reply #18 on: September 06, 2015, 06:45 PM »
^ correct. The spindle should fit really tightly against the bearings, so it may need a slight bit of welly to push it through
Offline downlowmatt
« Reply #19 on: September 07, 2015, 03:54 PM »
Thanks guys... I managed to get the arms off and spindle out.
I was using a wooden drift to try and punch the spindle out... I stopped.
I then used different sized screwdrivers and gently tapped them in to prize out the bearing covers on one side, then did the same on the other.
After that I then put in the profile allen key bolts (M10?) and rather than using the drift I put a t shirt around a copper hammer and gave it some welly! I got the non chainring side crank arm off first, then the other side slid out as you'd expect.
Just need to get the bearings out now, which I'll draft through from the opposite side of the frame (although there is that central spacer inside which prevents me from using a square extension bar, I'll have to get a flat head screwdriver or something).
Cheers!
