976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 12:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bent dropouts repair.
Author Topic: bent dropouts repair.  (Read 6671 times)
DJL
« on: March 10, 2010, 04:37 PM »
hi all,  i'm after some help,  please....
i've had a quick search but can't find the answers/info i'm after.  got a frame delivered and the rear dropouts are bent (as per the pics.)  i've been advised not to just bend them back as the powder needs removing,  dropouts need heating up etc etc,  basically,  it needs to be done properly to avoid any further problems.
can anyone point me in the right direction of someone who can do this work for me and who could give me an idea of costs etc.  thanks in advance.
neiljonarcus
Re: bent dropouts repair.
« Reply #1 on: March 10, 2010, 04:41 PM »
is the frame ali ?  you can stick them in a vice  or you a ajustable spanner  or you fingers
DJL
« Reply #2 on: March 10, 2010, 04:48 PM »
dunno mate,  its a tange frame,  not sure what material??  :-[
neiljonarcus
« Reply #3 on: March 10, 2010, 04:57 PM »
tange it will be cro-mo . but if there is powder on the frame its plastic and it will have some give on it  just be gentle useing your fingers . if its going to crack you will see it 1st in the powder  ........... just be slow and gentle
DJL
« Reply #4 on: March 10, 2010, 05:02 PM »
it will bend just by using your fingers??!!  will it weaken it at all just bending it back?
neiljonarcus
« Reply #5 on: March 10, 2010, 05:06 PM »
sorry mate  how old are you  ..... and have you ever been outside before ?
DJL
« Reply #6 on: March 10, 2010, 05:08 PM »
wtf is that supposed to mean?
bof
« Reply #7 on: March 10, 2010, 06:59 PM »
If you are worried about the powdercoat  , then try heating the dropouts in a pan of boiing water ( wear gloves it will be hot ) and slowly but sureley bend it back into shape with your hands , like N2cus said.
Offline HUTCHMAN
« Reply #8 on: March 10, 2010, 07:14 PM »
was that damage done by the courier? if it was, can't you put a claim in?
DJL
« Reply #9 on: March 10, 2010, 07:20 PM »
it was and a claims on the cards,  thats why i was asking where/who can do the repair because,  hopefully,  i'll have some money to pay for it.
can the bottom part of the dropout be pulled "down"  as well as left and right?
thanks for the help everyone.
Offline HUTCHMAN
« Reply #10 on: March 10, 2010, 07:27 PM »
If a claim's on the cards,get it done by a professional metal fabricators,heat will probably factor. then a re powder. Sting em for the full amount, although they'll probably try and wriggle out of it.
DJL
« Reply #11 on: March 10, 2010, 07:40 PM »
cheers hutchman,  i'll see how the claim pans out.
« Reply #12 on: March 10, 2010, 07:43 PM »
i'd be tempted to get a bit of cloth on em and a big set of adjustables and bend em back myself.
DJL
« Reply #13 on: March 10, 2010, 07:46 PM »
can you bend the bottom part down though?  i can see you could potentially bend them back in line left/right but what about downwards??
« Reply #14 on: March 10, 2010, 07:55 PM »
i would'nt have thought it would go down mate.
not without a lot of heat anyway.sawzall or animal are the men to pm.
how hard must they have dropped it to do that to your frame.
i'd have wrapped it round there necks.
Offline sawzall
« Reply #15 on: March 10, 2010, 07:57 PM »
if you get stuck you can give me a shout :daumenhoch:
DJL
« Reply #16 on: March 10, 2010, 08:05 PM »
thank you,  pm'd.
« Reply #17 on: March 10, 2010, 08:06 PM »
thats looks like it was done deliberately, whats the chance of both sides bending the same like that?    ???
get an anvil so it has a solid base, and a lump hammer, and a few smacks should cure it...   :daumenhoch:
DJL
« Reply #18 on: March 10, 2010, 08:10 PM »
i saw detailed pics before i bought it and the packaging was damaged when it was delivered.  it wasn't very well packed but it wasn't done deliberately.  hopefully the courier will cough up.
dannywhiteley
« Reply #19 on: March 10, 2010, 10:23 PM »
Thats why I pack dropouts so carefully when I sent a frame, they are so easy to damage.  Ive had one arrive similar to that but not as bad and unless you are careful and bend it back at the bend point you can easily put and 'S' in it.
I sent a TA frame forks this week and encased the drops in bubble wrap cos I know how little care these parcel we send actually recieve in transit. :rant:
monkian
« Reply #20 on: March 10, 2010, 10:37 PM »
Offline fugazi
« Reply #21 on: March 10, 2010, 10:51 PM »
Can You post up a pic of the dropouts from the side? Hard to give advice without  :daumenhoch:
« Reply #22 on: March 11, 2010, 08:12 AM »
 :LolLolLolLol: :LolLolLolLol:  at Monkian!
Offline Zippy
« Reply #23 on: March 11, 2010, 08:11 PM »
Pop the rear of the dropout in a vice wrapped in cotton or some other material. if you're carefull it will just go back into place. I've had to do that on a Tange frame inthe past as they're not the strongest in that area. After I'd done it you couldn't tell it had been bent to begin with.
