976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 04:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  how do ya dye ya mags
Author Topic: how do ya dye ya mags  (Read 1885 times)
Offline Wadz
  • Ride Ride Ride!!
« on: March 27, 2010, 08:30 AM »
i know the basics dye, salt,  hot water, but what do ya put it in, i used the bottom of a 250ltr  plastic barrel to bleach my mags,   i dont think this would be any good
to dye with as i need to keep the water at a constant heat, what have you lads used, and how long do you leave them in for.  ???
sweetbeats
Re: how do ya dye ya mags
« Reply #1 on: March 27, 2010, 08:57 AM »
Use the search function my friend...and the laws of the land will come forth and reveal themselves  :daumenhoch:
Or simply click on tech and restoration and click away  :coolsmiley:
Offline Wadz
  • Ride Ride Ride!!
« Reply #2 on: March 27, 2010, 09:39 AM »
tried that before, didnt find anything relating to what container was used, i'll have another look .
sweetbeats
« Reply #3 on: March 27, 2010, 09:40 AM »
Oil Drum,Bath (Not a plastic One).
sweetbeats
« Reply #4 on: March 27, 2010, 09:42 AM »
« Reply #5 on: March 27, 2010, 11:13 AM »
To do my Z rims I used a plastic bucket from whicks and used Snavs steam stripper method.
Basically boil up some water and then use a steam wall paper stripper with the plate taken off and put the hose in the water. The steam will keep the water boiling for ab out an hour and a half  :daumenhoch:
Offline Wadz
  • Ride Ride Ride!!
« Reply #6 on: March 27, 2010, 11:20 AM »
so a  plastic bucket was ok with keeping the water  boiling with the steamer, just have a image of the bucket collapsing with the heat. :-\
« Reply #7 on: March 27, 2010, 11:25 AM »
No it was fine, it was one of those 'rubble' plastic buckets with two large handles on each side....£7 in whicks  :daumenhoch:
The stripper was £19 from argos which worked really well and you've always got it for anything else, or to strip any wall paper  :daumenhoch:
« Last Edit: March 27, 2010, 11:26 AM by pickle »
Offline Wadz
  • Ride Ride Ride!!
« Reply #8 on: March 27, 2010, 11:44 AM »
cheers for that, daumenhoch:
