976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 11:52 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rounded off bolt!
Author Topic: Rounded off bolt!  (Read 1662 times)
Rounded off bolt!
« on: March 27, 2010, 12:16 PM »
my S&M Dirtbike arrived yesterday, wanted to begin stripping it as i want it re-sprayed. went to take the Odysses Posi Clamp off that came with it but the bolt is completley rounded! :'( how will i be able to get this off? HELP
Thanks Zak ;)
Offline Darren Wood
Re: Rounded off bolt!
« Reply #1 on: March 27, 2010, 12:23 PM »
Zack get a small hacksaw and cut through the bolt in the gap in the clamp  :daumenhoch:
WOODY  :4_17_5:
Offline brass monkey!
« Reply #2 on: March 27, 2010, 12:23 PM »
vice grips?
« Reply #3 on: March 27, 2010, 12:26 PM »
gave a little go with vice grips, to tight and wont budge!, might use a juniour hacksaw aswell Darren :daumenhoch:
bobbysam
« Reply #4 on: March 27, 2010, 01:46 PM »
you can always use a hacksaw to cut a slot in the bolt, and then use a screw driver to undo it.
« Reply #5 on: March 27, 2010, 02:05 PM »
thank you bobbysam, going to try that me thinks :daumenhoch:
« Reply #6 on: March 27, 2010, 02:50 PM »
Is it an allen key bolt that has rounded?  See if you can get a torx drive larger than the allen head and tap it in with a hammer, then undo  :daumenhoch:
bmxbob
« Reply #7 on: March 27, 2010, 04:00 PM »
whack a screwdriver into the alankey head, works for me !
if you cant sort it with a hammer you cant sort it with owt  ;D
« Reply #8 on: April 02, 2010, 11:48 PM »
