976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 07:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Finishing bare metal
Author Topic: Finishing bare metal  (Read 3847 times)
« on: April 04, 2010, 10:02 PM »
Whats the best finish for bare metal frames?
Cheers in advance  :daumenhoch:
Re: Finishing bare metal
« Reply #1 on: April 04, 2010, 10:13 PM »
have always fancied a raw frame, so stripping & polishing one ed. you will need to clear lacquer though as well otherwise it will rust :daumenhoch:
dave
« Reply #2 on: April 04, 2010, 10:14 PM »
well I thought the laquer route but I got told "it will just fall off" buy my neighbour who used to paint cars?
« Reply #3 on: April 04, 2010, 10:20 PM »
there's a few on here who have used laquer on raw frames, dirtbag diggler did his, im sure if he sees this he'll set you straight or try to finger you >:D
« Reply #4 on: April 04, 2010, 10:21 PM »
Mine is clear laquered Ed   :daumenhoch:
Offline superbikedan
« Reply #5 on: April 04, 2010, 10:31 PM »
tbh here ED your up against a hard one, i've rawed and lacqured a few frames in the past
and all fell foul the the rust creeping through, it just happens mate, it's only the frames that
are lacqured straight from manufactures seem to last longer but even those frames once chipped
start the old rusting, i recently just sprayed your brothers frame that was originally raw and fook me
it was in a bad state, real deep rust laying on the frame ???
« Reply #6 on: April 04, 2010, 10:41 PM »
Alright Dan - hes my brother-in-law  :angel: he told me it had been 'professionally rusted'  8)
I'll give it a coat of laquer and see what happens  :daumenhoch:
« Reply #7 on: April 05, 2010, 12:26 AM »
If you get the drop out Zinc plated it will act as a Sacrifical material an prevent the frame from corroding as the Zinc will corrode well before the frame  don't lacquer the Zinc bits.  I know it is not normal, but a warm frame spayed is less lightly to corrode.
« Reply #8 on: April 05, 2010, 08:24 AM »
can you come and spray it zinc in your druid outfit Brett...
and as far as scraficial materials work is goat any good  :LolLolLolLol:  :daumenhoch:
« Reply #9 on: April 06, 2010, 09:20 PM »
cheers Glen
I went and built it bare but I'm gonna strip it down and give it a few coats as you suggest.
Cheers  :daumenhoch:
calmac
« Reply #10 on: April 13, 2010, 07:55 PM »
I rawed my sons Proper Proclaimer a few months back & heard all the hoorors of lacquer & chips in it & rust getting under it so i thought sod that,don't want all that hassle.
Being a bit of a petrol head i always use top quality cleaning ,waxing products on my car & after rawing the frame i simply used a top quality Meguairs Carnuba wax sealant on the rawed frame & so far so good. All you need do is about once a month top up the wax.
Maintainance & good house keeping IE wipe of any water etc. when you get back from riding, it's the same with chrome rims,if you don't treat them well they're done in no time.
I have also rawed bars,crank arms,seatposts using the same methods.
Calum
« Reply #11 on: April 13, 2010, 09:29 PM »
Cheers Calum
I built the bike up raw so the idea of a wax to finish it off sounds well good!
Is this the one...
http://cgi.ebay.co.uk/Meguiars-Maguires-Car-Deep-Crystal-Step-3-Carnuba-Wax_W0QQitemZ370355782251QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item563aecc26b
Calum
calmac
« Reply #12 on: April 13, 2010, 11:53 PM »
Cheers Calum
Is this the one...
Calum
yeah thats the stuff
calum
« Reply #13 on: April 14, 2010, 08:37 AM »
I'm a go buy me some  8)
Then its Wax on Wax on like the Karate Kid  :angel:
wirewheel
« Reply #14 on: April 15, 2010, 08:00 AM »
before you laquer it give it a wipe over with strippers or solvent to get rid of any residue your hands will have left on the metal this is the worst thing for frames thats right SWEAT! when you get down to spraying make sure every in ch touched by human hands has been cleaned with solvent white spirit or summat thinners anything just stop touching the frame with hands then laquer it and laquer it and laquer it as many coats as possible for the best finish. its a hell of a lot less likely to flake or rust if the surface is clean before laquering, i have three frames to prove your mate the car sprayer he's wrong. it dont flake off.
remember with any spray job PREPARATION is way more important than anything
best of luck al.
Offline jT Racing
  • i like bikes. :/
« Reply #15 on: April 15, 2010, 08:04 AM »
i wonder how a frame would look with some chemical metal blue-ing ???
« Last Edit: April 15, 2010, 07:55 PM by J.T.Racing »
ding dong
« Reply #16 on: April 15, 2010, 04:50 PM »
mmm 'who' indeed...!  :LolLolLolLol:
i wonder who a frame would look with some chemical metal blue-ing ???
