976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 07:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stuvk seat post!!!!!!!!!!!!!!!!!!!
Author Topic: stuvk seat post!!!!!!!!!!!!!!!!!!!  (Read 1856 times)
Moza
« on: April 13, 2010, 07:02 PM »
I know this will have been asked many times but whats the best way to get one out ???? Im guessing heat ?????
antiquebmx
Re: stuvk seat post!!!!!!!!!!!!!!!!!!!
« Reply #1 on: April 13, 2010, 07:09 PM »
try and get some washing up liquid between post and frame, let it soak overnight.
then alot of twisting and pulling  :LolLolLolLol:
seriously, depends if you want the post, you could try and vice it and twist frame off
heat, maybe but never worked for me
Offline southern andy
« Reply #2 on: April 13, 2010, 07:25 PM »
I read somewhere that if you attach a handle bar stem to it you can put a longer pole over the stem shaft to act as a lever. I haven't tried it myself but it sounds a great idea.
Moza
« Reply #3 on: April 13, 2010, 07:27 PM »
Thanks guys no I dont need the post so I can KILL IT !!!!!!!!!!!!!!!! ive sprayed some wd40 on it for now, its a steel fluted so its ran down ok  :daumenhoch:
antiquebmx
« Reply #4 on: April 13, 2010, 07:29 PM »
if its fluted might be able to get some vice grips on it
« Reply #5 on: April 14, 2010, 01:56 PM »
Try Diesel instead of WD40 and leave for a couple of days, works a treat then hit the top of the seat post with a big hammer to try and break the "weld" before getting any grips or stilsons on it  :daumenhoch:
PK6061
« Reply #6 on: April 14, 2010, 05:12 PM »
same as marty try diesel first. dont forget if its a steel frame' the alloy post will probs
         heat up and expand before the frame. if all fails alloy posts can be drilled out :daumenhoch:
Offline popedante
« Reply #7 on: April 14, 2010, 05:17 PM »
^^^ this works , put an old stem on the post , then whack the stem with the biggest hammer you got
( away from frame,not into frame ) :daumenhoch:
