Pro class problem
bobafett:
--- Quote from: Foxxy on May 20, 2010, 08:21 PM ---
I had already tried what you suggested but the stem simply won't go in. :'(
--- End quote ---
Well I don't understand mate - it should fit :-\
Is the inside of the fork tube corroded ? Thick bits of rust etc ? Maybe try rubbing around the inside of the tube with a large round file ???
Other than that I just don't know mate, unless the fork tube is squashed :-\
Does it go in slightly and then stop a bit tight or will it not even start to go in ?
Fook knows :LolLolLolLol:
Foxxy:
Bobafett,
Success! ;D Did what you suggested with a file and eventually it went in, so well pleased. Again, thanks for your help.
Foxxy
bobafett:
Good stuff :daumenhoch:
diesel:
If its only just going in then you might want to rub a bit of lithium grease around the inside, otherwise it'll all fuse together and you'll never get the bugger out without damaging something.
dj-paul-c:
--- Quote from: diesel on May 23, 2010, 06:55 AM ---you'll never get the bugger out without damaging something.
--- End quote ---
the damaged part normally ends up my knuckles
Navigation
[0] Message Index
[*] Previous page
Go to full version
