976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 01:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear drops on a Harry Leary Turbo?
Author Topic: Rear drops on a Harry Leary Turbo?  (Read 2440 times)
martylaa
« on: May 17, 2010, 08:18 AM »
Ones i have seen have a silver/chrome protection on the rear dropouts, what are these and where can i get some?
Re: Rear drops on a Harry Leary Turbo?
« Reply #1 on: May 17, 2010, 08:22 AM »
i maybe well wrong here.....but i'm guessing the original finish was deliberately masked off on the dropouts so it didn't get chipped or break when the wheels get tightened?
just a theory though as i know fook all about em  ;D
martylaa
« Reply #2 on: May 17, 2010, 08:25 AM »
sounds about right, bollocks.......
cheers pickle the paint is very delicate as i found out yesterday
« Reply #3 on: May 17, 2010, 12:00 PM »
isn't it a kind of laquer over chrome finish?  all finishing over the top of chrome comes off very easy i'm afraid....tis a very delicate finish which is why hardly any i've seen are pristine.  lovely looking though  :daumenhoch:
Offline sparky
« Reply #4 on: May 17, 2010, 01:13 PM »
The silver areas on the rear and fork dropouts is the standard Chrome base prior to the Smoke being applied (it was for effect more than anything else). A tacky substance was applied to the areas (type of masking) so not to create a too course edging because the coating (six coats of blue-black paint and four coats of clear, then baked) had a tendancy to chip. The masking could then be removed without impacting the smoke paint. :daumenhoch:
martylaa
« Reply #5 on: May 17, 2010, 01:19 PM »
cheers mark, i thought the painters would have done this seeing as they were the ones doing the leary paint, never mind too late now, its chipped a little on the rear dropout.... :knuppel2:
« Last Edit: May 17, 2010, 06:09 PM by martylaa »
louisdog
« Reply #6 on: May 17, 2010, 06:06 PM »
Here's the drop outs on my HLT
the radius is 13mm or the size of a 2p piece
i used this to score round with a very sharp scalpel and then used a steel rule, then picked off the laquer leaving the chrome and a perfect edge
forks are the same but 12.5mm use a 10p , hope this helps chap  :daumenhoch:
martylaa
« Reply #7 on: May 17, 2010, 06:10 PM »
looks like something i may have to do thanks for the tips :daumenhoch:
« Reply #8 on: May 17, 2010, 07:57 PM »
alternatively del may be able to provide you with some chrome decals to go round the area, then no need to risc damaging your paint, like i did....
Offline Redline
« Reply #9 on: May 19, 2010, 12:46 PM »
... Never realised ya did that with yours Sammy..... ya big cheat  :LolLolLolLol:
J
« Reply #10 on: May 19, 2010, 02:15 PM »
when i saw you had posted i knew you was going to rip into me!!! :LolLolLolLol:
Offline Redline
« Reply #11 on: May 20, 2010, 09:05 AM »
 :LolLolLolLol:  :LolLolLolLol:  :LolLolLolLol:
lmfao ..... easy target buddy  :2funny:
