976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 03:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  what size spokes
Author Topic: what size spokes  (Read 4149 times)
Offline Waxintaxin
what size spokes
« on: June 07, 2010, 12:12 PM »
7x 20inch to suntour sealed low flange hubs
is it 194mm ?
Offline Stodgy
    • RADBMX Shop
Re: what size spokes
« Reply #1 on: June 07, 2010, 12:13 PM »
194mm 4-cross
186mm 3-cross
Offline Waxintaxin
« Reply #2 on: June 07, 2010, 12:14 PM »
so what was the right cross for 80s wheels
« Reply #3 on: June 07, 2010, 07:37 PM »
3x for racing, 4x for freestyle
« Reply #4 on: June 07, 2010, 08:51 PM »
or radial if you just wanna be cool
« Reply #5 on: June 09, 2010, 12:31 PM »
so what size for radial laced ?.
« Reply #6 on: June 09, 2010, 03:17 PM »
X2  :)   Large flange hubs and small  ???
Offline gary4130
« Reply #7 on: June 09, 2010, 06:26 PM »
used 180's on my front suzue low flange open bearing hub into a 7x rim
166's on a suzue large flange hub(36h) +also a gt mohawk hub (48) both int a sun black box rim
« Reply #8 on: June 09, 2010, 07:09 PM »
Cheers mate  :daumenhoch:
« Reply #9 on: June 09, 2010, 10:00 PM »
Offline gary4130
« Reply #10 on: June 09, 2010, 10:22 PM »
nice +easy to lace up -just make sure all spokes get the same number of turns,got both of mine trued +straight without having to get them to the lbs  :daumenhoch:
« Reply #11 on: June 09, 2010, 10:26 PM »
any pics of the ones you have done with the radial lacing mate  ???
« Reply #12 on: June 09, 2010, 10:38 PM »
Here are some of my bikes with radial lacing....
Front..
Rear... Radial non-drive side, 3x drive side (really good fun to bulid, LOL).
« Reply #13 on: June 09, 2010, 10:43 PM »
Nevermind the spoking
look at the Campagnolo Tipos and snakebellies  :smitten: :smitten: :smitten: :smitten: :smitten: :smitten: :smitten: :smitten: :smitten:
« Reply #14 on: June 09, 2010, 11:25 PM »
Front..
Cheers Sean , they look fookin splendid  :4_17_5: :daumenhoch:
Got to have a go at that myself  :D  Is Gary right when he says 166mm on a large flange hub  ???
That DeCoster is superb mate , one of my favourite bikes at MK last year  :smitten:
« Reply #15 on: June 10, 2010, 07:41 AM »
Joff
Gary sounds right with his calculations, but it all depends on the measurements of the hubs and rims.  I think mine on the DeCoster were 162mm and I had to have them custom cut and threaded.
« Reply #16 on: June 10, 2010, 08:25 AM »
Cheers Sean  :daumenhoch:
Looks like the old micrometer and spoke calculator are comming out then  ::)  :LolLolLolLol:
« Reply #17 on: June 10, 2010, 08:41 AM »
That is the best way mate, that is what I use to make sure I have the correct spoke length.
Offline gary4130
« Reply #18 on: June 11, 2010, 03:10 PM »
here's a couple of pics of my wheels
first pic is suzue low flange into a 7x rim
with a 180 spoke for ref
next up is gt mohawk hub  into a sun black box rim
then suzue hi flange into sun black box rim
here i've just put 166mm spoke next to suzue large flange/7x rim
wheels all laced up fine-no spokes sticking out of rim etc-but as sean said depends on hub/rims
got my info from custom riders,gave them hub/rim combo ,hope this helps ask if you need any more pics  :daumenhoch:
« Reply #19 on: June 11, 2010, 03:55 PM »
Your a good man Gary  :daumenhoch:
Wheels look great mate , defo doing some of these  :4_17_5:
