976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 05:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bb info needed please
Author Topic: bb info needed please  (Read 2075 times)
motomagII
« on: April 10, 2006, 08:01 PM »
just bought frame with euro bb on it .i have 3 piece but has got usa bb set on it can i get the euro bb set and still use this crank and spindle or are they totally different ?please .ps i dont know the axle size if this does make difference .cheers guys
Offline Nosnod
Re: bb info needed please
« Reply #1 on: April 10, 2006, 09:01 PM »
Should be fine
I bought a new set of dual pinch flites for my Cruiser and they came with both a Euro and US BB which utilised the same axle
silentpartner
« Reply #2 on: April 10, 2006, 09:01 PM »
you should be able to use your existing cranks, it all depends on the spindle. if its a square tapered one most old school, and alot of new cranks will fit. it gets a bit more comlicated if your using splined or specialist spindeled cranks. if the cranks dont match the spindle you've got try alan woods, at alansbmx, he'll sort you out with what you need.
alan  ;)
motomagII
« Reply #3 on: April 10, 2006, 09:03 PM »
the cranks are nwe school and not very good quality they are only db ones the axle is splined too
hutchboy
« Reply #4 on: April 10, 2006, 09:35 PM »
unless its an oversized spindle then a 19mm euro bb should be ok on that
« Reply #5 on: April 11, 2006, 08:55 AM »
greg halfords should do the euro bb for them as the spindle is lighlty bigger than the profile
axle as i had mine machined down mate to fit lol
weston
« Reply #6 on: April 11, 2006, 06:08 PM »
spoke to ben manual at halfords, he said get in touch with custom riders, they do a pack for about £30 that will sort you out..
