decals won't stay stuck...
<< < (3/3)
brass monkey!:
had a similar issue with foil backed Torker fork decals, in the end i put a dab of Pritt Stick on em, and it has sorted the problem... :)
southern andy:
I'm sure you can get an adhesive spray. 3M or scotchguard do something like it.
We used to use it for vinyl's at work when they weren't very sticky.
Maybe one of these may work, just spray the back of the sticker and fit too frame.
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=adhesive+spray&_sacat=See-All-Categories
20to26:
good idea! that's next if my hairdried-maksing-taped decal trick doesn't work... thanks Andy
DJL:
did the hairdryer work?  if not did you find a way of getting them to stick?  i'm having the same problem......
mark 2:
--- Quote from: stevochb on June 18, 2010, 11:31 AM ---Ive got the same problem with my kuw decals, they went on fine but after a couple of days started lifting at the edges :(
--- End quote ---
I'm in the club
Navigation
[0] Message Index
[*] Previous page
Go to full version
