976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 07:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat post help
Author Topic: seat post help  (Read 2980 times)
seat post help
« on: June 29, 2010, 06:45 PM »
Got a 90's assassin frame and it measures 22.2 across the seat tube hole, but when i put the 22.2 post in it's like a cock up an alley way and won't tighten
any help?  does it require a special size?  Jai.....any advice?  :daumenhoch:
Offline R Al
Re: seat post help
« Reply #1 on: June 29, 2010, 06:50 PM »
Both mine took a 22.2, try the seatclamp the other way round as the split is at the front
Offline HUTCHMAN
Re: seat post help
« Reply #2 on: June 29, 2010, 07:00 PM »
I had to use a larger size in my Assassin,possibily 22.6
Re: seat post help
« Reply #3 on: June 29, 2010, 07:02 PM »
tried it the other way but A. didn't like the look and B. it would pinch the frame tube to tighten it that much so was not the correct size post.
so you can get 22.6 then  ???
Offline HUTCHMAN
Re: seat post help
« Reply #4 on: June 29, 2010, 07:07 PM »
i think it was something like 22.6(it was a Hutch Hi-caliber post that would'nt fit ANY Hutch frames i've got)and you could see the slight taper where the seat guts clamped on,so the majority of the post was obviously larger diameter.
Re: seat post help
« Reply #5 on: June 29, 2010, 07:14 PM »
sure mines  a 22.2 also . its an odessey post if that helps u at all.
Re: seat post help
« Reply #6 on: June 29, 2010, 07:20 PM »
i tried 3 posts, GT, Renthal and Haro fusion but all miles to small  :-\
Re: seat post help
« Reply #7 on: June 29, 2010, 07:57 PM »
i will go try mine  one mo
Re: seat post help
« Reply #8 on: June 29, 2010, 08:05 PM »
mine is identical to a regular old school post ,tight as a nuns ..22.2  it has to be twisted a touch but smooth at that size snug
Re: seat post help
« Reply #9 on: June 29, 2010, 08:10 PM »
fooking wierd Dan......i'll try and get a picture of the hole (oooooh er Mrs)  ;D
Offline se-bmxer
Re: seat post help
« Reply #10 on: June 29, 2010, 08:12 PM »
Rob i have a Shimano DX seatpost in my assassin not sure what size it is though
i can check the Assassins we have left at work and see what size they are  :daumenhoch:
Re: seat post help
« Reply #11 on: June 29, 2010, 08:13 PM »
here you go....
says 22.2 but it fooking aint!!   >:(
yeah that'll be great Jai.....huge thanks for all your help guys!  :daumenhoch:
Offline mattfx81
Re: seat post help
« Reply #12 on: June 29, 2010, 08:57 PM »
Make a shim out of a coke can.
Matt
Re: seat post help
« Reply #13 on: June 30, 2010, 07:07 AM »
that will be the last resort  :daumenhoch:
Offline kev-s
Re: seat post help
« Reply #14 on: July 01, 2010, 09:25 AM »
lol was gonna suggest the same thing, this is what i done with my mtb frame
Re: seat post help
« Reply #15 on: July 08, 2010, 08:32 AM »
i have gone down the pepsi can shim road for the moment, but i also have a TNT twin bolt clamp on the way over from the states so should be better for clamping with the reversed slot style seat tube  :daumenhoch:
