976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 12:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Old school skyway sprocket - how do I get it off?
Author Topic: Old school skyway sprocket - how do I get it off?  (Read 7084 times)
Plinth Adenoid
« on: July 17, 2010, 05:52 PM »
Hi all
My build is coming along nicely, I'm currently cleaning the rear tuff before dipping in bleach. As I want to ensure the hubs are protected from bleach this time (the front hub is a dull grey colour now) I am in the throes of taking the sprocket off (it was missing a number of bearings, slipping and wobbly as hell anyway).
I took the front of it off, left handed thread, millions of tiny bearings everywhere... out came two shims and a spring with two teeth on it but now I'm left with this and can't get it off.
I've tried big mole grips, drifting with a protected screwdriver etc but it ain't shifting...
Help!
Thanks again for a fab site everyone.
snav69
Re: Old school skyway sprocket - how do I get it off?
« Reply #1 on: July 17, 2010, 05:56 PM »
Have you tried it with the axle out  ???
That may be holding it in  :-\
 :coolsmiley:
Offline fischflo
« Reply #2 on: July 17, 2010, 06:50 PM »
or just use loads of grease  :LolLolLolLol:
i'm not sure  if you got a suntour cassette style hub or not, (but if yes, this might help against the wobble:
http://www.vintagebmx.com/community/index.php's=ef2fa9bf3d9fce9244ddac72593c5772&showtopic=4002460&hl=\wobbly+old+tuff\    :daumenhoch:)
« Last Edit: July 17, 2010, 08:45 PM by fischflo »
Offline Moose
« Reply #3 on: July 17, 2010, 08:06 PM »
How did you remove it? Did you use a special tool?
Did it look like this before you removed anything?
« Last Edit: July 17, 2010, 08:13 PM by Moose »
Plinth Adenoid
« Reply #4 on: July 17, 2010, 08:24 PM »
Yeh it did, except it's a 16T SIA sprocket. I undid the front race (clearly not the way to go, I've recovered 78 tiny ball bearings so far...)
So I took the toothed wheel off and what's left is the bottom bearing race. I think it's screwed on by looking at the fit. I might just buy a replacement and leave the old race in place, it's in pretty good nick.
« Last Edit: July 17, 2010, 08:26 PM by Plinth Adenoid »
Offline sawzall
« Reply #5 on: July 17, 2010, 08:31 PM »
try clamping it in a vice and use wheel to turn it,if that fails the only other way is
to get some 5mm plate and carefully weld it on to the remaining
freewheel then unscrew while still hot and it should come off easily ;)
« Reply #6 on: July 17, 2010, 08:36 PM »
be carefull though if you crush it in a vice, you might crush the hub, i'd try some big fook-off stilsons carefully with loads of leverage...
Offline Moose
« Reply #7 on: July 17, 2010, 08:40 PM »
You should have used one of these:
Plinth Adenoid
« Reply #8 on: July 17, 2010, 08:43 PM »
What's that and how's it work moose?
Offline Moose
« Reply #9 on: July 17, 2010, 08:47 PM »
It's a freewheel removal tool and I find the best way to use them is to clamp the tool in a vice, locate the 'pins' in the slots of the freewheel and turn the wheel.
Not sure it'll work now you've destroyed the freewheel  :LolLolLolLol:
And you need to get the right one (2-pin or 4-pin).
bmxbob
« Reply #10 on: July 17, 2010, 08:49 PM »
A big hammer  :LolLolLolLol:
Offline fischflo
« Reply #11 on: July 17, 2010, 08:50 PM »
it was a flip-flop style hub btw not cassette
Plinth Adenoid
« Reply #12 on: July 17, 2010, 08:54 PM »
Lol Moose, it's nit that bad, it all goes back together ok, I have all the bearings that were left in it and can screw it back together ok, I want to get it off so I can protect the hub when I put the wheel in bleach.
I can't see where that removal tool would go (ahem). Where on the freewheel are the pins for that tool?
« Reply #13 on: July 17, 2010, 08:57 PM »
screw it back together ( dont worry about the bearings ) take it to the lbs and they will have the correct removal tool to get it off. doubt if they will charge you if you buy summat ;)
Flugee
« Reply #14 on: July 17, 2010, 08:59 PM »
Offline fischflo
« Reply #15 on: July 17, 2010, 09:04 PM »
lol..... whats going on here ?  :LolLolLolLol:
Offline Moose
« Reply #16 on: July 17, 2010, 09:05 PM »
In the picture of the freewheel I posted you'll see two rectangular 'slots' on the inside, that's where the tool locates  :daumenhoch:
snav69
« Reply #17 on: July 17, 2010, 09:07 PM »
I misread it at first and thought it was a coaster hub and you wanted it all out  :-[ although it now looks like a suntour cassette hub  :-\
Clamp it in a vice as Phil says  ;)
 :coolsmiley:
Offline fischflo
« Reply #18 on: July 17, 2010, 09:09 PM »
NO   NOT cassette ....... flip-flop or whatever it's called, but it's not cassette, it turns out  :D
« Last Edit: July 17, 2010, 09:20 PM by fischflo »
Offline Moose
« Reply #19 on: July 17, 2010, 09:18 PM »
Offline fischflo
« Reply #20 on: July 17, 2010, 09:20 PM »
Say, you did not take that freewheel thing, that Moose's picture shows, apart? ...you managed to get that off in its entirety, right?
Plinth Adenoid
« Reply #21 on: July 17, 2010, 09:22 PM »
 :LolLolLolLol: Your a gent Moose, I will owe you several pints when I've finished this bike :)
I've put mine back together to show the lack of removal tool slots, I have to destroy the freewheel to get it off, a la the second link you sent.
Thanks for the chisel recommendation but won't be taking a chisel to my tuff II's :)
Offline fischflo
« Reply #22 on: July 17, 2010, 09:26 PM »
aha,  destructive removal LOL
stepp 7. "Dispose of the freewheel parts and install a new one. "2    :LolLolLolLol:
Offline Moose
« Reply #23 on: July 17, 2010, 09:28 PM »
Then Phil was right from the off  :daumenhoch:
Offline sawzall
« Reply #24 on: July 17, 2010, 09:49 PM »
now you have it back together this is the best way to remove it,tack weld a piece
of bar across freewheel making sure it won't turn,then use bar as lever and freewheel will come off,
do it while it's still hot as this will help it  ;)
