Stem stuck
<< < (2/2)
Muffski:
Yep,cheers Moley ,all sorted now :daumenhoch:
next question is removing the cups from the crank housing? do i need a special tool(other than myself ::))
--- Quote from: moley on August 29, 2010, 06:41 PM ---Make sure your wheels, seat and bars are still on!!
Its far easier when your sat down, holding the front wheel and twisting the bars and whacking it off at the same time!!  :D
--- End quote ---
58 delray:
--- Quote from: Muffski on August 29, 2010, 06:51 PM ---Yep,cheers Moley ,all sorted now :daumenhoch:
--- End quote ---
--- End quote ---
use a drift (bit like a long thick centre punch) and a hammer  :daumenhoch:
moochalargo:
Yeah hammer n drift for the bb and wiggle wiggle with the stem mate
moley:
Use an extension bar from a socket set and tap it out with a hammer.
The extension bar end will be slighty rounded so it wont damage the cups too much.  Dont use anything sharp like a screwdriver etc, etc.
When you reinstall everything..................use plenty of grease on everything apart from brake pads, rims and your seat and grips etc, etc   :LolLolLolLol:
Basically any metal on metal mechanical gubbins.  It will stop squeaking from components and it will make it easier to install and remove afterwards if you want to change anything.
Muffski:
Cheers for Help   :-* :4_17_5:
--- Quote from: moley on August 30, 2010, 02:25 PM ---Use an extension bar from a socket set and tap it out with a hammer.
--- End quote ---
Navigation
[0] Message Index
[*] Previous page
Go to full version
