976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 04, 2026, 05:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bottom Bracket Tool - Which one? (MORE PHOTOS)
Author Topic: Bottom Bracket Tool - Which one? (MORE PHOTOS)  (Read 6546 times)
Offline diesel
« on: August 31, 2010, 02:46 PM »
Looking for a tool to fit this bottom bracket
Its a small suntour bb. It has 8 splines - I can get more photos if that helps?
« Last Edit: September 01, 2010, 09:50 AM by diesel »
Re: Bottom Bracket Tool - Which one to Buy?
« Reply #1 on: August 31, 2010, 02:52 PM »
Try this link Dan, it's the tool you need  :daumenhoch:
http://www.parktool.com/products/detail.asp?cat=25&item=HCW-5
moley
« Reply #2 on: August 31, 2010, 03:12 PM »
http://www.parktool.com/repair/readhowto.asp?id=93
I have one of these tools but its very multi-purpose and OS-ly in design.
Does your BB have 6 notches?
Does it also have 2 pin holes in the center like the top picture?    If it does then you'll need a pin spanner!!
  Do any of the modern BB tools fit your BB?
Offline diesel
« Reply #3 on: August 31, 2010, 03:22 PM »
I'm going to have to get you more photos
Forgot to mention they are internal spines
spesh
« Reply #4 on: August 31, 2010, 03:35 PM »
looks like a normal cassette type bb with lock rings
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=689
Offline diesel
Re: Bottom Bracket Tool - Which one? (MORE PHOTOS)
« Reply #5 on: September 01, 2010, 09:53 AM »
Ok I've got a better photo to illustrate my dilema:
8 splined internal BB - 30mm
H.E.L.P please  :daumenhoch:
moley
« Reply #6 on: September 01, 2010, 10:56 AM »
Would this one do it?
http://www.parktool.com/products/detail.asp?cat=25&item=BBT%2D18
Is there a Suntour Part number for the BB?
This is a suntour bottom bracket spanner!!    Whether it fits yours I dont know!!!
http://cgi.ebay.com/Vintage-Suntour-Bicycle-Bottom-Bracket-Spanner-Tool-NOS-/350387463376?pt=LH_DefaultDomain_0&hash=item5194b864d0
Have you tried using a screwdriver and tapping it out?
Offline diesel
« Reply #7 on: September 01, 2010, 10:58 AM »
Thanks, that Suntour tool would probably work... but that postage is a bit high if it dosen't  :-[
moley
« Reply #8 on: September 01, 2010, 11:12 AM »
I might have something that fits but I'd have to check the dimensions!!
PM me tonight to remind me!!
The only other way is get someone to make a tool.    Rooski might be able to do it!!
snav69
moley
« Reply #10 on: September 02, 2010, 12:07 AM »
Park Tool OBW-3 spanner has a 14mm spanner end and a 30mm diameter brake centering tool end (for caliper brakes to adjust the springs to centre the brake)
The outside diameter of the 2 blades is 30mm and the inside is 26mm with each blade being 2mm thick.   Each blade is around 4mm min to 5mm max wide (I'm using a shitty ruler to measure.
If the gaps between the spines are around 4-5mm then it should fit okay!!
http://www.google.co.uk/products?hl=en&q=park+tool+obw-3&scoring=p
Offline diesel
« Reply #11 on: September 02, 2010, 01:32 PM »
spot on thank you  :daumenhoch:
Offline diesel
« Reply #13 on: September 02, 2010, 07:23 PM »
Well that might be your reason for spending a little more time in the workshop Pete  ;D
