976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 04, 2026, 01:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brazing with refillable butane blowtorch??
Author Topic: brazing with refillable butane blowtorch??  (Read 2928 times)
firebird4130
« on: September 07, 2010, 03:49 PM »
would it be possible to do some brazing with a refillable blowtorch that uses lighter gas?
Cheers  :daumenhoch:
Fraz
snav69
Re: brazing with refillable butane blowtorch??
« Reply #1 on: September 07, 2010, 03:55 PM »
I would say Yes  ;) as we used something simillar at school  :daumenhoch:
Sawzall is your man to ask though  ;)
 :coolsmiley:
firebird4130
« Reply #2 on: September 07, 2010, 04:55 PM »
cool, I'll give it a go then, Got some bars I want to extend  :daumenhoch:
Offline steve69
  • aka. Steve Changa
« Reply #3 on: September 07, 2010, 09:45 PM »
Hi Fraz, If there not chrome send them up to me and i'll weld a bit on for you.
You got my address :daumenhoch:
firebird4130
« Reply #4 on: September 07, 2010, 11:02 PM »
cheers for the offer mate, they are chrome though, does that make em harder to weld?
Offline steve69
  • aka. Steve Changa
« Reply #5 on: September 08, 2010, 09:13 AM »
you would need to grind off/remove the chrome to weld it, no major problem if your using them as it would be covered by the grips  ;)
LMK, cheers Steve.
firebird4130
« Reply #6 on: September 08, 2010, 10:05 AM »
cheers for the advice mate I'll be sure to grind the chrome down on that area, I've ordered the blowtorch now will lt you know how it goes  :daumenhoch:
Offline steve69
  • aka. Steve Changa
« Reply #7 on: September 08, 2010, 10:35 AM »
you know where i am if it doesn't work out ;)
firebird4130
« Reply #8 on: September 08, 2010, 10:46 AM »
cheers mate  :daumenhoch:  no doubt you'll be hearing from me  :LolLolLolLol:
Offline HUTCHMAN
« Reply #9 on: September 08, 2010, 10:57 AM »
bear in mind you'll have to achieve temperatures above 840 F.
firebird4130
« Reply #10 on: September 08, 2010, 02:16 PM »
so this is doomed to failure?  :LolLolLolLol:
Offline mattfx81
« Reply #11 on: September 08, 2010, 02:27 PM »
If they are for a rider then you would best go for a fused joint and get them welded using mig or tig.
