976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 04, 2026, 12:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  dia compe 880 problem with fitting
Author Topic: dia compe 880 problem with fitting  (Read 1504 times)
JOE
« on: September 11, 2010, 11:17 AM »
I recently bought some dia compe 880 brakes off the bay for my burner mk2 but im having trobble fitting them to the forks :(, i've taken a couple of pics so you can see the problem
theres like a lip sort of thing which is stoping it from completely goin through the hole in the forks, which means i cant put the bolt on :(
is there a way around this problem or have a wasted my money?
Joe
Offline HUTCHMAN
Re: dia compe 880 problem with fitting
« Reply #1 on: September 11, 2010, 11:30 AM »
the centering jobbies are missing
ozone
« Reply #2 on: September 11, 2010, 01:43 PM »
I've had lots of pairs of FS880 brakes and none of them had centering hardware.  I would throw the spindle that came with them and use a standard one.   :daumenhoch:
Offline Steve P
« Reply #3 on: September 11, 2010, 02:53 PM »
The hole in the curved washer is shaped to fit over the flat sides on the centreing spindle ... you could either drill a larger hole through it or file a couple of flats instead  :daumenhoch:
« Reply #4 on: September 11, 2010, 07:29 PM »
That has the wrong spindle in it there pal.  The spindle fitted is off an mx1000.  I would see you local bike shop and see if they can help with a replacement or put something in the wanted section here and swap it out
JOE
« Reply #5 on: September 12, 2010, 09:17 PM »
thanks all :), i'll have to get a replacement spindle for it then
