976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 11:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Powdercoat stripping tips please?
Author Topic: Powdercoat stripping tips please?  (Read 4668 times)
Skyway tuffshit
« on: September 13, 2010, 09:41 AM »
Hi all. Can someone tell me the easiest, cheapest and best ways to strip a frame, forks, bars and seat post ready for re powdering please? Is there anything I need to do to them afterwards before sending for powdering? Thanks for your time
curtispro
Re: Powdercoat stripping tips please?
« Reply #1 on: September 13, 2010, 09:46 AM »
Hi
I stripped my sons GT race bike back to the alloy using nothing more that a tin of Nitromors, a paint brush, water to wash it off, took about 3 hours :daumenhoch:
Skyway tuffshit
« Reply #2 on: September 13, 2010, 10:52 AM »
Thanks for the tip. Will I get nitromors from a car parts shop or anywhere like B&Q? Do I need to do anything to the bits after to prep for powdering? Thanks again for your help. Will this also work on cranks as I have a White 401 flight to strip down too.
trasher
« Reply #3 on: September 13, 2010, 11:40 AM »
Nitromores won't remove powder
You need permatex gasket remover
If your sending it to dan , he will do all the prep for you
« Reply #4 on: September 13, 2010, 11:43 AM »
the gay pensioner is right, Nitomors won't touch powdercoat.  I went to a local car body supply suppliers and bought some really strong paint remover and that takes it off but it is a long job.
curtispro
« Reply #5 on: September 13, 2010, 11:46 AM »
It removed all the paint from the GT, maybe not powder? 2008 Power series came off very easy :)
Skyway tuffshit
« Reply #6 on: September 13, 2010, 12:18 PM »
Thanks for all your help. Not sure who's doing the powdering yet but after seeing Dans work I'd be stupid to go anywhere else.
trasher
« Reply #7 on: September 13, 2010, 01:01 PM »
It removes paint alright , but believe me it won't touch decent  powder
This has been discussed on here before
Mate it's a no brainer to send to anyone else  :crazy2:
I made that mistake when I first started
A local guy did it for £15
And it was a bag if shite
As said , dan will remove the powder for you
And refinish as part of his service
I'm  Sure he'll be along soon  :daumenhoch:
spesh
« Reply #8 on: September 13, 2010, 01:59 PM »
if your tight and what to remove it yourself then buy a wire wheel in a drill it works but it messy i stripped a burner frame n forks in about 30 minutes and ware a mask :daumenhoch:
Offline Peter J
  • I have issues
« Reply #9 on: September 13, 2010, 02:11 PM »
Media Blasting  :daumenhoch:
curtispro
« Reply #10 on: September 13, 2010, 03:13 PM »
I was going to do my other sons Redline using the same thing, it came of the GT fine, bubbled up like a goodun  :), will have to try on a small bit first before I strip it all down, maybe I was lucky  :daumenhoch:
Offline superbikedan
« Reply #11 on: September 13, 2010, 05:06 PM »
tbh who ever you use should be able to strip the old paint for you,  saves you £15 to £20
on strippers that may not work :daumenhoch:
« Reply #12 on: September 13, 2010, 05:18 PM »
i use loafers of essex
trasher
« Reply #13 on: September 13, 2010, 06:11 PM »
£15 -£20 on strippers  ???
Bet they were rough
« Reply #14 on: September 13, 2010, 07:18 PM »
I use an oxy/acetelene gas axe and a wire brush  ::)
« Reply #15 on: September 14, 2010, 01:15 PM »
And your chromers use a hammer and a vice  :-X  :LolLolLolLol:
Sorry, bad tast I know  :-[
Dr Skyway
« Reply #16 on: September 18, 2010, 10:26 AM »
Quote
think that has just answered one of my questions in another thread    :daumenhoch:
is permatex ok to use on an ally frame?
Offline Del
  • Re-living my youth!
« Reply #17 on: September 19, 2010, 04:30 PM »
yep! not a problem
