976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 02:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Brake rub on Tuff ll
Author Topic: Brake rub on Tuff ll  (Read 2499 times)
Shiner
« on: October 03, 2010, 08:53 PM »
Iv'e seen some alot of tuff's with brake rub on.   :( I've just changed my wheels to Black Tuff ll and at this moment have Dia Compe brake pads which are BLACK. Will these's pads be OK because there black? or will they mark? Should I be looking to get some black Tuff pads? are they made different to prevent marking?
Cheers  :daumenhoch:
D
Re: Brake rub on Tuff ll
« Reply #1 on: October 03, 2010, 09:05 PM »
All pads mark in some way as thats the nature of 'braking' but rocking black on black is going to make it less noticeable.
If you did get Tuff Pads then you would get more effective braking as they are made for the job  :daumenhoch:
Offline Munnyella
« Reply #2 on: October 03, 2010, 09:08 PM »
I have Stodgy's best clear pads on my white tuffs, they leave brown/red marks, dependant on where you ride. I's clearly not the pads, but the muck they rub in.
All comes off with some magic elbow.
Shiner
« Reply #3 on: October 03, 2010, 09:41 PM »
 :daumenhoch: I'll think I'll get some black tuff pads and store it till the summer  :LolLolLolLol:. Any tips on how or what to clean brown brake marks/ stains of white tuffs?
Offline Munnyella
« Reply #4 on: October 03, 2010, 09:47 PM »
Cif (thats Jif to us old schoolers), T cut, nail varnish remover, 1200 wet or dry.
use what shifts it easiest! I have tried them all, I like them with tan lines now!!
Shiner
« Reply #5 on: October 03, 2010, 10:18 PM »
  :LolLolLolLol: I'll better get some Jif as well then and start scrubbing  :(   :daumenhoch:
Offline john4130
« Reply #6 on: October 04, 2010, 09:30 AM »
the best stuff i've ever used on tuffs is bar keepers friend, you can get it in asda. i tried loads of different things and nothing shifted brake rub as good as it, you dont need to use much elbow grease with it either. just a small amount on a damp cloth and away you go.
Shiner
« Reply #7 on: October 04, 2010, 09:42 AM »
Back down Asda AGAIN  :LolLolLolLol:
« Reply #8 on: October 04, 2010, 10:39 AM »
bar keepers friend eh. off to get some of that, had a set of white mags sat in bleach since 1pm yesterday, prior to that i rubbed them to death with jif to no avail, so once they are outta the bleach i will be trying this stuff, cheers for the advice
Offline john4130
« Reply #9 on: October 05, 2010, 05:44 PM »
you tried it out yet? how did it go.
« Reply #10 on: October 05, 2010, 07:03 PM »
Saw soem of that Bar Keepers friend in CO-OP... was tempted  :angel:
will get some next time  :daumenhoch: and give it a raz.
Was also tempted by various JML products... like that magic stain rubber... and cleaning gel... anyone tried those?
Offline glenboy
« Reply #11 on: October 06, 2010, 01:23 AM »
brillo pad works with soapy water but its laborious
Shiner
« Reply #12 on: October 06, 2010, 09:53 AM »
Haven't tried any think yet, Wifey said she will pick up some Bar Keepers friend at Asda and came back with out it  >:( I'll pick some up and plus with all the over cleaning products Cif, nail varnish, bleech etc I now have, let you know what I found to work best.
