976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 09:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  cracked frame
Author Topic: cracked frame  (Read 1934 times)
snooze
cracked frame
« on: October 11, 2010, 06:28 PM »
I have a crack that goes right around my eat post tube right under the seat clamp. I spoke to a guy who says they have to cut off the top and weld a seat clamp to it. does anyone on here know of another way of getting this done in London? I don'r want my seatclamp welded  :-\
snooze
Re: cracked frame
« Reply #1 on: October 13, 2010, 01:13 PM »
here it is.
you can see the shim is poking out at the top of the seatpost tube
Offline fischflo
Re: cracked frame
« Reply #2 on: October 13, 2010, 02:21 PM »
I had a similar case, had the seat tube replaced and glad I've done it that way. Someone here can surely recommend you a good shop for this in/around London  :)
Re: cracked frame
« Reply #3 on: October 13, 2010, 05:00 PM »
There are a couple of good people here that can do that for you, Sawzall springs to mind first (legend at fixing the unfixable) and there are a couple of other posted in the Technical stickies section.
Try sending Phil (Sawzall) a PM to see if he can help  :daumenhoch:
snooze
Re: cracked frame
« Reply #4 on: October 13, 2010, 06:20 PM »
Thanks for the advice I'll check out these leads, I didn't know you could replace the seat post tube.
I'm new to this site so not so sure how to use it, I had a look for Phil Sawzall's info in the section mentioned but can't seem to find it. Does anyone have any contact details for this man?
Thanks again for the help
« Last Edit: October 13, 2010, 06:51 PM by snooze »
Offline Peter J
  • I have issues
snooze
Re: cracked frame
« Reply #6 on: October 14, 2010, 12:22 AM »
Thanks a lot peter j.
in the meantime I'll wait for Chuck to find me ;)
Offline Peter J
  • I have issues
Re: cracked frame
« Reply #7 on: October 14, 2010, 02:45 PM »
 ;D
