976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 03:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  quick giro q
Author Topic: quick giro q  (Read 2723 times)
motomagII
quick giro q
« on: April 25, 2006, 09:47 PM »
right me new frame hasnt got any tabs for gyro on it can i still fit one and what do i buy and how do they fit etc etc .pretend you are dealing with novice as when it comes to new school i am cheers greg
Offline ORB
Re: quick giro q
« Reply #1 on: April 25, 2006, 09:55 PM »
the cup will have the tabs in mate
just press it in and bingo.
12
motomagII
Re: quick giro q
« Reply #2 on: April 25, 2006, 09:56 PM »
i was wanting to use the giro from a gt but the frame has tabs on it so i presume fromt his i need a different giro ?
Offline ORB
Re: quick giro q
« Reply #3 on: April 25, 2006, 10:07 PM »
just the bottom cup
i think i have a 1.1/8 one
will look tomorrow if you remind me.
12
motomagII
Re: quick giro q
« Reply #4 on: April 28, 2006, 06:19 PM »
anyone else help me out please
Offline BrianP
Re: quick giro q
« Reply #5 on: April 28, 2006, 07:37 PM »
will have a go!
b4 gyro tabs were fairly standard on frames, they used a cable hanger type thing which u fitted between your top headset cup and the top of the headtube.
i'll have a look tonight and see if i have one, which u can have no probs.
I know i've at least one here, but it may be for a 1" headset, not the newer 1 1/8".
will let you know later.
motomagII
Re: quick giro q
« Reply #6 on: April 28, 2006, 07:56 PM »
thanks mate that sounds cool if you can find it greg
Offline BrianP
Re: quick giro q
« Reply #7 on: April 28, 2006, 08:09 PM »
you're in luck!
got top and btm tabs from an sst oryg to suit the 1 1/8" headset.
only thing that is different between the oryg and the gyro is the size of the threads on the adjuster barrels.
(jeez, ignore the dodgy perspective on the pics. they are a matching pair, ;))
the cables usually come with both, but i probably also have these if u need some?
brianp
Offline aditup2004
Re: quick giro q
« Reply #8 on: April 28, 2006, 10:15 PM »
Gregster, I am gonna remove my Giro, so you can have mine. LMK, Ad
