976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 05:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Headset for Aero Reflex
Author Topic: Headset for Aero Reflex  (Read 1735 times)
Superkav
« on: May 01, 2006, 10:11 AM »
Tried a couple of cheap ones from Billys.co.uk but they seem a bit too big and I don't want to fook it up, what headset have you Reflex owners used??
Offline sawzall
Re: Headset for Aero Reflex
« Reply #1 on: May 01, 2006, 10:16 AM »
on my daughters aero i used a diamond back one ,under £4 from halfuc*ks had no probs with it :daumenhoch:
Offline Steve P
« Reply #2 on: May 01, 2006, 10:26 AM »
I used the Hatta MX100 alloy set on mine
The Tioga Beartrap and MX-600 will be OK too . . . contact Wolfy
Steve  :daumenhoch:
Offline Rombloke
  • do one
« Reply #3 on: May 01, 2006, 02:50 PM »
headsets are meant to be 'f' tight
Dave
haro, how do you do
retrogeezer
« Reply #4 on: May 01, 2006, 10:33 PM »
did crack an Aero Reflex head tube putting in an alloy Hatta headset.....was using a proper install tool as well.
Offline Steve P
« Reply #5 on: May 01, 2006, 11:44 PM »
I find the MX100 steel top race is always a swine to press in to any frame so I increase the starting taper on a bench grinder
Works every time
Steve  :daumenhoch:
