976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 06:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Polishing Alloy
Author Topic: Polishing Alloy  (Read 4281 times)
YGT
Polishing Alloy
« on: May 01, 2006, 01:35 PM »
anyone got any tips, or recomend the best type of machinery for a lazy ol git  :LolLolLolLol:
revcore
Re: Polishing Alloy
« Reply #1 on: May 01, 2006, 01:48 PM »
A buffing wheel should do the trick. But if you want to polish a frame then I would recommend a hand held Dremel polisher for the hard to get at sections but for the main sections use a buffer
Offline ORB
Re: Polishing Alloy
« Reply #2 on: May 01, 2006, 02:12 PM »
elbow grease
12
Re: Polishing Alloy
« Reply #3 on: May 01, 2006, 02:39 PM »
autosol.
Offline Rombloke
  • do one
Re: Polishing Alloy
« Reply #4 on: May 01, 2006, 02:45 PM »
orb is right, a polishing wheel and a dremmel is a quick way to do it, i do have both, but always finish of by hand(fnar fnar), gives a great finish. work your way through the grits of wet and dry, till you get to somthing like a 1200 grit.
then, with a clean cloth go at it with autosol, then peek, then tcut, i always give my polished alloy a good coat of wax after too to try and stop it oxsidising(sp).
the results you can get by hand are amazing. ive polished lots of parts up this way, but most recently was a pro neck stem which i got from waxin, it wasnt looking too clever when i got it, but an hour or so's polishing i ended up with this......
good luck
Dave
haro, how do you do
Offline Rombloke
  • do one
Re: Polishing Alloy
« Reply #5 on: May 01, 2006, 02:46 PM »
another....
Dave
haro, how do you do
Offline Rombloke
  • do one
Re: Polishing Alloy
« Reply #6 on: May 01, 2006, 02:49 PM »
polished tuff hub......you see all by hand....
ooh i do like a nice polish
Dave
haro, how do you do
Re: Polishing Alloy
« Reply #7 on: May 01, 2006, 04:31 PM »
you sound like frank spencer.
Offline Rombloke
  • do one
Re: Polishing Alloy
« Reply #8 on: May 01, 2006, 05:51 PM »
yes...i do all my own stunts too!!!
mmm...betty
Dave
haro, how do you do
rad dad
Re: Polishing Alloy
« Reply #9 on: May 01, 2006, 07:58 PM »
 ;D
Offline sawzall
Re: Polishing Alloy
« Reply #10 on: May 01, 2006, 08:32 PM »
i polished everything on my ripper using a 1400 rpm motor with polishing mop conversion or you could
get yourself a bench grinder and convert it to a polisher, try machine mart they do all you will need,it will save you a lot of elbow grease and in the long run alot of cash!!!!!!
steve
Re: Polishing Alloy
« Reply #11 on: May 01, 2006, 11:08 PM »
are they chrome vinyl stickers on that pk?
Re: Polishing Alloy
« Reply #12 on: May 02, 2006, 01:26 AM »
that ripper is super shiny
the thing gleams. i'd sack the pads though. let the metal show. esp the stem
revcore
Re: Polishing Alloy
« Reply #13 on: May 02, 2006, 02:05 AM »
good luck
Dave
 ;D Yes....ORB is right. Taking credit for my words of wisdom,  :LolLolLolLol:
Offline sawzall
Re: Polishing Alloy
« Reply #14 on: May 02, 2006, 05:59 PM »
yes steve they are chrome vinyl,i had them made by a guy who does our decals at work,i just wanted to do something a little bit different :daumenhoch:
FuNMoNsTeR
Re: Polishing Alloy
« Reply #15 on: May 02, 2006, 06:09 PM »
Nice work guys :daumenhoch:
I usually start with 100 grit wet n dry to get out any deeper marks and scratches and then wet n dry down the grades to 2000 grit. final sand is with a well used 2000 grit piece to get superfine scratches. Then 2 cream polishes to finish(autosol). I use a hard felt mandrel for the first cream polish and a soft lambswool mandrel for the final polish.
 I have a video if anyone wants to borrow it. It is proffesional polishing techiques by the CETEM finishing school. It shows you how to set up all the mops (sanding and polishing) on a bench mounted drill type system ;)
steve
Re: Polishing Alloy
« Reply #16 on: May 02, 2006, 07:04 PM »
ahem
-i can do them in chrome
-chrome gold
-alloy
brushed alloy
plus all  the other colours
