976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 09:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rust removal from spokes / rims
Author Topic: Rust removal from spokes / rims  (Read 4777 times)
crillmeister
« on: January 16, 2011, 09:38 AM »
After a bit advice really on how to remove rust from spokes and rims,or at least a cheap way. I've just purchased a Blue Max and the frame isn't to bad at all just a few small spots of rust but nothing too serious but the spokes are quite rusty almost black on a few of them.
Or are they beyond saving!
motomagII
Re: Rust removal from spokes / rims
« Reply #1 on: January 16, 2011, 09:48 AM »
to be honest id get em respoked with new spokes if ya want em looking good they are pretty bad
crillmeister
« Reply #2 on: January 16, 2011, 10:07 AM »
Thought as much, but to be honest will probably use this as a rider so they don't necessarily need to look mint just better than they currently do but with minimum cost!!!
motomagII
« Reply #3 on: January 16, 2011, 10:13 AM »
well to get em better get some wet and dry paper and wd40 and give em rub down they will come up reasonable but it takes ages to do .
monkian
« Reply #4 on: January 16, 2011, 10:18 AM »
I think someone once mentioned using a cork and polish ???
« Reply #5 on: January 16, 2011, 01:11 PM »
I think someone once mentioned using their c0ck and polish ???
???    >:D
« Reply #6 on: January 16, 2011, 01:18 PM »
Just respoke them it doesn't take long to do then the wheels will look a million dollars and to is alot easier to clean the rims and hubs aswell :daumenhoch:
« Last Edit: January 16, 2011, 02:17 PM by brettypeeps »
Offline Gary72
« Reply #7 on: January 16, 2011, 02:12 PM »
Could try vinegar :daumenhoch:
trasher
« Reply #8 on: January 16, 2011, 02:32 PM »
take the spindles out ,,and drop the wheels  in some oxalic acid ,,,,job done  :daumenhoch:
before
after
« Last Edit: January 17, 2011, 08:42 PM by trasher »
Offline stevochb
« Reply #9 on: January 16, 2011, 08:45 PM »
Try soaking the spokes in jiff lemmon juice and then give them a rub with a bit of autosol :daumenhoch: thes turned out ok.
Had sore fingers for a few days though :LolLolLolLol:
« Last Edit: January 16, 2011, 08:48 PM by stevochb »
ozone
« Reply #10 on: January 17, 2011, 02:21 PM »
Remember to remove the freewheel before you remove the spokes from the rear hub as they are really difficult / almost impossible to remove once the wheel has been stripped.  The freewheel would be in the way of the spoke holes when you come to rebuild the wheel.  :daumenhoch:
oldsnow
« Reply #11 on: January 17, 2011, 07:05 PM »
cork & autosol cheap and effective !  :angel:
trasher
crillmeister
« Reply #13 on: January 17, 2011, 09:21 PM »
« Reply #14 on: January 18, 2011, 10:45 PM »
Personally I use citric acid powder mixed with water - safe, cheap and works perfectly  :daumenhoch:
You can find it on ebay  ;)
