Tuff Wheel help!
oldtired:
skyway replacement hubs had a philips pan head bolt with them i seem to remember ? so it would look just like a swapped hub , from bitd, reason being is to allow as much room as possible on the cog side. if the bolt head is to big you'll turn it into a fixie when you bung the chain on :LolLolLolLol:
dordymush:
you could buy the nuts and bolts from b & q for the hubs.i got some from there myself in the past.
have a word with jay how he done his blue hubbed tuffs and im sure rombloke dave had an idea with the rivots a while back.
CD17:
Matt do not remove the rivets, call me & I will tell you how to do it 8)
Swivel:
--- Quote from: wish id kept my TA on January 18, 2011, 05:36 PM ---Matt do not remove the rivets, call me & I will tell you how to do it 8)
--- End quote ---
I'll do that chris mate, thanks :daumenhoch:
oldtired:
--- End quote ---
+1 on that, arn't they a bit fatter on one side , because of the way they are made, i think if you pull em through the wrong way it will crack the wheel , might be wrong though?
Navigation
[0] Message Index
[*] Previous page
Go to full version
