976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 02:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  advice please on removing decals cleanly
Author Topic: advice please on removing decals cleanly  (Read 2264 times)
« on: January 27, 2011, 09:26 PM »
good evening radsters
I've ordered some nice new decals for my haro from Del the decal master  8)
will shortly have to remove the ones that are on there so would appreciate any tips on how to remove them cleanly without damaging the powder underneath
cheers
Re: advice please on removing decals cleanly
« Reply #1 on: January 27, 2011, 09:28 PM »
Use a hair dryer it will soft the adhesive a bit and they should come off a treat :daumenhoch:
« Reply #2 on: January 27, 2011, 09:44 PM »
a big fookin hammer and chisel..sorted >:D
« Reply #3 on: January 27, 2011, 10:09 PM »
thanks brett - sure mrs griff has one lurking somewhere  :daumenhoch:
will wait until the new ones arrive first (so I can remember where they go)
any tips on removing adhesive stuck on frame? or do you reckon they'll come off clean?
actually brett while I'm on - do you have any pics of your bars close up so I can see where the decals are supposed to go?
tanks fer nuttin  ::)
« Reply #4 on: January 27, 2011, 10:12 PM »
yes defo hairdryer pulled some off a powdered frame years ago and pulled powder off  :2gunsfiring_v1:
i use some low odour white spirit to clean the rest off  :daumenhoch:
The Burner King
« Reply #5 on: January 27, 2011, 10:34 PM »
Buy some isopropyl alcohol from e-bay, it will get the sticky residue off without marking the paint, its better than white spirit as white spirit will thin the paint if you rub too hard. Its pretty cheap as well.  :daumenhoch:
« Reply #6 on: January 27, 2011, 10:35 PM »
^^^^ :daumenhoch:  then wash it with fairy liquid solution
Isopropyl will do the Job as well without leaving a residue
« Last Edit: January 27, 2011, 10:37 PM by brettypeeps »
« Reply #7 on: January 27, 2011, 10:43 PM »
cheers all for advice - will have a look for some isopropyl then  :daumenhoch:
and thanks brett for pics - don't think I've seen those ones before  8)
