thicko
<< < (2/2)
RATTY:
Ignore the tards in the corner!!!
If its a US BB (Big one with a one piece crank) then you need to remove the pedals first, then undo the lock nut first  (remember its a left hand thread!). Then remove the washer, then undo the the large one the same way. Remove the bearing race and slide the crank out the other side. :daumenhoch:
Last edit by RATTY, after a jack daniels and a reminder from spesh :angel:
spesh:
--- Quote from: RATTY on February 04, 2011, 10:06 PM ---Ignore the tards in the corner!!!
If its a US BB (Big one with a one piece crank) then you need to remove the pedals first, then undo the lock nut first  (remember its a right hand thread!). Then remove the washer, then undo the the large one the same way. Remove the bearing race and slide the crank out the other side. :daumenhoch:
--- End quote ---
its a left hand thread!!!!!!! std threads are right hand :LolLolLolLol:
GavinKent:
thanks all!!  ive managed to undo the nut and now the bigger one, with the slot like a screw - i was able to undo the same way but getting tight - do i use a hammer and put screwdriver into slot and tap a bit???
spesh:
no turn it back and give the thread a clean,it should unscrew without much effort :daumenhoch:
GavinKent:
ahhhh, i started undoing it the wrong bloody way again!
now ive managed to do the difficult bit, i just need to find a spanner to undo the bloody pedals!
Navigation
[0] Message Index
[*] Previous page
Go to full version
