976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 08:57 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  thicko
Author Topic: thicko  (Read 2792 times)
GavinKent
thicko
« on: February 04, 2011, 09:20 PM »
please - how do i change my pedal arm - do i undo the nut on the bracket on the opposite side of the chain??  :idiot2:
Offline Del
  • Re-living my youth!
Re: thicko
« Reply #1 on: February 04, 2011, 09:33 PM »
it be easier if you could post up a pic of the set up you have, then I'm sure someone can guide you.
Re: thicko
« Reply #2 on: February 04, 2011, 09:43 PM »
if tefore answers ignore him, he's proper good at fittin cranks
Re: thicko
« Reply #3 on: February 04, 2011, 09:46 PM »
was like a calling for you this thread eh pete  :2funny:
Re: thicko
« Reply #4 on: February 04, 2011, 10:01 PM »
thats just put your parcel back 3 more days  :yahoo_silent:
Re: thicko
« Reply #5 on: February 04, 2011, 10:06 PM »
Ignore the tards in the corner!!!
If its a US BB (Big one with a one piece crank) then you need to remove the pedals first, then undo the lock nut first  (remember its a left hand thread!). Then remove the washer, then undo the the large one the same way. Remove the bearing race and slide the crank out the other side. :daumenhoch:
Last edit by RATTY, after a jack daniels and a reminder from spesh :angel:
« Last Edit: February 04, 2011, 10:22 PM by RATTY »
spesh
Re: thicko
« Reply #6 on: February 04, 2011, 10:14 PM »
If its a US BB (Big one with a one piece crank) then you need to remove the pedals first, then undo the lock nut first  (remember its a right hand thread!). Then remove the washer, then undo the the large one the same way. Remove the bearing race and slide the crank out the other side. :daumenhoch:
its a left hand thread!!!!!!! std threads are right hand :LolLolLolLol:
GavinKent
Re: thicko
« Reply #7 on: February 05, 2011, 09:09 AM »
thanks all!!  ive managed to undo the nut and now the bigger one, with the slot like a screw - i was able to undo the same way but getting tight - do i use a hammer and put screwdriver into slot and tap a bit???
spesh
Re: thicko
« Reply #8 on: February 05, 2011, 09:26 AM »
no turn it back and give the thread a clean,it should unscrew without much effort :daumenhoch:
GavinKent
Re: thicko
« Reply #9 on: February 05, 2011, 12:49 PM »
ahhhh, i started undoing it the wrong bloody way again!
now ive managed to do the difficult bit, i just need to find a spanner to undo the bloody pedals!
