976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 05:38 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  acs boa 16mm nut to 10mm thread conversion.raaaa PICS ADDED
Author Topic: acs boa 16mm nut to 10mm thread conversion.raaaa PICS ADDED  (Read 4643 times)
energiza
« on: February 11, 2011, 01:49 PM »
Right brought 2 nos acs boa.s from a fello rad member.and they are both large thread rears.so had a brain wave.tryed tap n di.ng the thread down to 6mm.not good.these are some proper solid threads on these boa.s     :-\  so another brainwave come to my head.took me 30 mins :) and a presto it only bloody worked.ive done one already.so ill be taking some step by step pics of the next one i convert today.so hopefully it will help out u fella members who have them thick arsed thread ones layin about collecting dust  :smitten:
« Last Edit: February 11, 2011, 05:31 PM by energiza »
bof
Re: acs boa 10mm to 6mm thread conversion.raaaa
« Reply #1 on: February 11, 2011, 02:11 PM »
I reckon a 10mm drill would be the easiest way . Do you need pictures ?
Offline GTnumber1
« Reply #2 on: February 11, 2011, 03:41 PM »
+ 1 and your never going to cut that thread smaller, change the spindles its a peace of piss just dont loose all the bearings  :daumenhoch:
energiza
« Reply #3 on: February 11, 2011, 04:00 PM »
 :D i did take one apart originaly and it took me about 2hrs to but all them lil bars##rd bearing back in,so gave up on that idea..these are to use on rider.solid as a rock
1st pic before and after
1st tools required lol
use them saws
wheres that chunky thread gone
energiza
« Reply #4 on: February 11, 2011, 04:06 PM »
part2 file down so level with spring holder
then 3mm drillbit to start you off
working drill sizes up from 3mm/4mm/5mm then 6mm
not the straightest of 6mm holes,but a it works
get your 6mm thread,wak on some super strenght chemical metal and put in 6mm hole.leave to dry for a day and wooo a 6mm boa is born again lol
Offline john4130
Re: acs boa 10mm to 6mm thread conversion.raaaa PICS ADDED
« Reply #5 on: February 11, 2011, 05:22 PM »
i'm still using the same 10mm boa for about 15-17 years. i sent it too rob ridge who would machine it out and put sealed bearings and a 10mm axle on it. i've never had a problem with it ever.
energiza
« Reply #6 on: February 11, 2011, 05:28 PM »
Best brakes ever i say.the threads where 16mm nut size originally.so instead of killin a good set of forks 10mm nut thread size was the way forward for me :)
ozone
Re: acs boa 16mm nut to 10mm thread conversion.raaaa PICS ADDED
« Reply #7 on: February 11, 2011, 05:51 PM »
Be interesting to see how the mod holds up under use - repeated heavy braking etc.   :daumenhoch:
energiza
« Reply #8 on: February 11, 2011, 06:22 PM »
the chemical metal is usally pucker.my mate used it on his cracked forks years ago and the forks are still alive
bof
« Reply #9 on: February 11, 2011, 09:41 PM »
I stand by my original post as the best method . You have got to be mad to even consider using that brake in anger  :D
dan-dare
« Reply #10 on: February 11, 2011, 09:46 PM »
and use a centre punch before drrrrrrriiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiilllllllllllllllllllllllllllllllllllllllllllllllllllllliiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiinnnnnnnnnnnnnnnnnnnnnnnnnnnnnnggggggg.  :angel:
energiza
« Reply #11 on: February 11, 2011, 10:36 PM »
:daumenhoch:i need to invest in one m8..lol
Offline GTnumber1
« Reply #12 on: February 12, 2011, 12:00 AM »
+ 1  :daumenhoch:
Offline Betty
« Reply #13 on: February 12, 2011, 11:06 AM »
Chemical metal? Is that some sort of glue?
You'd trust a brake thats been glued together...  :idiot2:
2 minutes turkish...
energiza
« Reply #14 on: February 12, 2011, 01:55 PM »
 ::) lol i forgot to say in above posts.that the drilled hole as to be tap n di.ed out.so there is a thread inside to screw the 6mm thread into.the chemical metal is a kinda glue.but its made from 2 tubes of stuff that react together when applyed to any metal source.creating a bond as strong as a weld.almost like metal.this was squeezed into hole then 6mm thread screwed in after.so should be strong enough
bof
« Reply #15 on: February 19, 2011, 11:14 PM »
11mm drill bit
dirt bike brake slot for 6mm spindle
drill in position
hole drilled brake installed 5 minutes later
energiza
« Reply #16 on: February 20, 2011, 08:46 AM »
 :'( owwwww poor frame.i could.nt drill a frame out just for a brake.ouchhhh
Offline Betty
« Reply #17 on: February 20, 2011, 11:11 AM »
Makes more sense now...  :daumenhoch:
Bof's method takes the win though...  :4_17_5:
bof
« Reply #18 on: February 20, 2011, 10:41 PM »
The dirt bike deserves no sympathy.  :LolLolLolLol:
but a brake that works far outweighs damage that can be done from a flipped manual  :daumenhoch:
