anyone know if mr muscle oven cleaner will remove ano?.....
<< < (4/4)
Dannywhac:
Just remember you can always add - so start off with 1/3 mug of Caustic to a gallon (8 pints) of water. Stir it in slowly, add what you wanna strip (keep it off the base of the container you're stripping in - I use old arcade stick blanks to keep rims etc off the base). After 10 mins remove the item, and see if the anno will rub off - if not pop it back in for another few mins. If that doesn't work, take out the part, add more Caustic and pop it back in.
Two other important things - DO NOT do this in an area that isn't well ventilated (as the reaction creates nasty gas) and wear gloves  :daumenhoch:
BENDYCAT ELEVENTEEN:
and tights + hot pants  then go out in the street part - most important that bit is  ;)
Dannywhac:
--- Quote from: BENDYCAT ELEVENTEEN on February 15, 2011, 09:58 AM ---and tights + hot pants  then go out in the street part - most important that bit is  ;)
--- End quote ---
Sequined hot pants purlease ;)
ED209:
--- Quote from: griff on February 14, 2011, 05:48 PM ---
--- Quote from: ED209º on February 14, 2011, 05:02 PM ---FFS tight wad... I'll post you some fookin oven pride in a little pot...  8)
--- End quote ---
can you just use a bit of oven pride in one go then? thought I'd have to use it all in one go....  :-[ ::)
will probably just get some of that then, don't want Ed posting me strange white powder in the mail  ;D
need to get back onto ebay and find some wheels, will check in later
--- End quote ---
its a gooey liquid
heres Snav in action in one of my fav pics from RADBMX  ^"^
Dannywhac:
--- Quote from: ED209º on February 15, 2011, 01:34 PM ---its a gooey liquid
--- End quote ---
I had that problem 'arise' with an ex-girlfriend - I accidently banjo-stringed meself - ooof  :-[
Navigation
[0] Message Index
[*] Previous page
Go to full version
