976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 05:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oven Pride and anodizing question..
Author Topic: Oven Pride and anodizing question..  (Read 5624 times)
« on: February 20, 2011, 09:57 PM »
...which is...
can Oven Pride stop working? i.e. not strip anodizing anymore
is their some types of anodizing that it can't remove...
worked fine for me in he past but the last 2 things haven't worked??? had the bottle for 3/4 months  :angel:
is it too cold? or too old?  ^"^ I don't know  :)
Re: Oven Pride and anodizing question..
« Reply #1 on: February 20, 2011, 10:15 PM »
I don't think it will shift Hard Anno  :-\ i think that needs blasting off  :shocked:
What are they that you have  ???
 :coolsmiley:
Were's the pic of you with blood and tubes in your gloved hands when you need it  >:D
I did some new school pegs and they were great but its not worked on a Dyno seat post ( mid school )  and old school Sugino spider???
lets get the blaster out...  :D
« Reply #2 on: February 20, 2011, 10:20 PM »
 :coolsmiley:
Is it this one ?
« Reply #3 on: February 21, 2011, 12:29 AM »
could try a stanley blade to help hook bits off,  depending how much is left on the item
« Reply #4 on: February 21, 2011, 07:37 AM »
 :coolsmiley:
Is it this one ?
it was before that one... this one.. :)
ozone
« Reply #5 on: February 21, 2011, 08:43 AM »
 :coolsmiley:
If it was a black Sugino spider, it didn't work because they were painted.  Get the Nitro-Mors out - might be worth trying that with the post, you never know...
« Reply #6 on: February 22, 2011, 08:24 AM »
It worked in the end ... 4 x 1/2 hour coatings and it was off  >:D
« Reply #7 on: February 22, 2011, 01:11 PM »
 :coolsmiley:
Is it this one ?
looks like you bobbet'd your self  ;D
Offline southern andy
« Reply #8 on: February 22, 2011, 01:42 PM »
 :coolsmiley:
Is it this one ?
Ouch, i bet Paul will never poke a Renthal post up his arse again.
« Reply #9 on: February 22, 2011, 04:06 PM »
i've had to put nitromors on some anno bits in the past as the oven pride would'nt touch it.
dont know if it was a lacquer on it but once that was off the oven pride worked well.
Offline HARORIDER
« Reply #10 on: February 22, 2011, 04:32 PM »
defo works better at room temp so leaving it in a shed or clod garage slows down it's performance :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #11 on: February 22, 2011, 05:05 PM »
last time i saw a seat post like that it had a Team Murray at one end and a young kid attached at the other ,   Cantley track about 82 ish  ,    crappy plastic yellow seat snapped , mind you, mine did too but i only got ring ripper,     his was well in there  :-X    :shocked: :shocked:
« Reply #12 on: February 22, 2011, 06:10 PM »
truth accepted.
I had it in the hoose for a couple of nights and warmed the seat post up as well ( see Snavs picture )  :buck2:
then it worked betterer.
waza04
« Reply #13 on: February 22, 2011, 09:09 PM »
go wilko mate, pick up some caustic soda..... make a weak mix to start, then drop your bits in! blasts it off in seconds.  :daumenhoch:
crightonk
« Reply #14 on: February 24, 2011, 08:50 PM »
I take my bits to work, there's a tank of caustic for cleaning turbine parts and as you say seconds and it's stripped, sorry that doesn't help you :-[
« Last Edit: February 24, 2011, 08:54 PM by crightonk »
« Reply #15 on: February 25, 2011, 09:08 AM »
just returned from hospital having followed your advice  :shocked: :buck2:
 ;D
waza04
« Reply #16 on: February 25, 2011, 11:42 AM »
 ;D
obviously there are some safety factors to take into account.................   :coolsmiley:
