976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 08:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Raleigh TAP - Skyway Advice required
Author Topic: Raleigh TAP - Skyway Advice required  (Read 5421 times)
StellaAtoiz
« on: February 23, 2011, 11:07 AM »
Having just managed to get shot of a Raleigh Team Aero Pro over the last couple of weeks, another showed up on the bay at a silly Buy It Now price - I left it a couple of hours to allow a Burner enthusiast to snap it up, but as they did not bother, I thought I would ???
I wonder if any of you guys in the know could give some advice on the Skyways on it - this is a pic of the one I just got shot of which had alloy hubbed Skyways both front and rear;
....and this is a pic of the one I have just got, which has an alloy hubbed rear only;
FRONT;
REAR;
My question is - is the front a new type Skyway :-\
Also, the tyres are Mitsuboshi and the walls appear to be dirty white in colour, would these have simply lost their colour over the years or did Mitsuboshi do white wall comp III's?
....bit of an odd stem on it as well :-\
Thanks for your time :daumenhoch:
ozone
Re: Raleigh TAP - Skyway Advice required
« Reply #1 on: February 23, 2011, 11:19 AM »
Is the bike from 1985?  I'm sure it was '85 when Skyway phased out the alloy hub and a lot of bikes came equipped with an alloy rear hub and plastic front.  Probably the original wheels the bike came with IMO.
A bit of a pain to sell on their own as people prefer either alloy or plastic pairs of wheels, not a mixture of both.
« Reply #2 on: February 23, 2011, 11:21 AM »
hi jase
you keep coming up with these tasty ap's. i must get one one day
the front wheel is an 80's looseball tuff so id say 1985+ think they did sets of alloy rear and placky front but sure someone on here will know for sure
as for the tyres that looks like the walls may have perished. if you have cleaned the bike skinwalled tyres can go white when wet but when they dry out will return to skin colour  :daumenhoch: :daumenhoch:
personally i like the rear alloy and plastic front as a lot of my bikes are 1985
StellaAtoiz
« Reply #3 on: February 23, 2011, 11:25 AM »
Thanks for that chaps :daumenhoch:.......at least the front is kind of era correct.
Just checked the underside of the BB - my last one had a date stamp on it, however this one does not so I can't put a year to it unfortunately :-\
« Reply #4 on: February 23, 2011, 11:34 AM »
looks sweet! deffo original tuffs from around 85.....and not cracks either as they tended to develope hairline cracks around the hub  :daumenhoch:
monkian
« Reply #5 on: February 23, 2011, 11:38 AM »
What's the date on the frame?
StellaAtoiz
« Reply #6 on: February 23, 2011, 11:42 AM »
Cheers Pickle ;)
Monkian - I can't seem to find a date on the frame :-\
Offline WINI
  • Sheeping it real ;-)
« Reply #7 on: February 23, 2011, 12:00 PM »
I've got an 85 World Tour as the pic below, and also came with original alloy/plastic combo.  kinda like it, its got character
Offline 58 delray
« Reply #8 on: February 23, 2011, 12:07 PM »
when skyway brought the plastic hubs out in the mid 80s they had loads of alloy hubbbed rears left so for a while set came as alloy rear/plastic front.
i can remember selling them like this bitd in the bike shop i worked in  :daumenhoch:
monkian
« Reply #9 on: February 23, 2011, 12:11 PM »
Cheers Pickle ;)
Is there a Serial No on the BB? ???
StellaAtoiz
« Reply #10 on: February 23, 2011, 12:14 PM »
Thanks for that Andy :daumenhoch:
Monkian - strangely enough there is no stamp on the BB :-\
The TAP that I sold a couple of weeks back did have a date stamp on the BB - however this was a factory painted over chrome frame.
The one I have no is not chrome beneath......if this makes a difference :coolsmiley:??
monkian
« Reply #11 on: February 23, 2011, 01:50 PM »
Not sure about that. One for the burner boys ;)
While we're at it:
Were the non-stamped TAP frames still Tange made? ???
It's definitely an mid 80's front you got there :daumenhoch:
Changed over 84/85.
StellaAtoiz
« Reply #12 on: February 23, 2011, 01:52 PM »
Ooops..... ::)......so it looks like I have bought a ringer :shocked: :'( ;D
Oh well, still worth the money I paid I suppose :daumenhoch:
monkian
« Reply #13 on: February 23, 2011, 02:03 PM »
Don't worry man. I'm sure it's sound :daumenhoch:
I think Raleigh might have just changed manufacturers at some point.
« Last Edit: February 23, 2011, 02:05 PM by monkian »
StellaAtoiz
« Reply #14 on: February 23, 2011, 02:11 PM »
....thats not like Raleigh to be inconsistent :shocked: :2funny:
monkian
« Reply #15 on: February 23, 2011, 03:25 PM »
Most likely a budget thing. Probably a cheaper supplier ::)
I see Zippy has answered this over on Rewind...
Raleigh moved away from Tange to Koisumi for production of the AP/TAP.
Think they made one or two others in the range as well.
Dave's MkII Custom Cromo 'Night' Burner is also Koisumi made :daumenhoch:
Offline Glynnyboy
« Reply #16 on: February 24, 2011, 03:08 PM »
Jase check the rear dropouts. There were two sorts of team ap. The tange with the serial on the underneath of the BB and a Koisumi made frame which i believe the serial was on one of the rear dropouts, it would have the baseball sign with it.
Failing that it is most likely that the paint is to thick to see the serial on the bb and it's tange.
Offline beard1973
« Reply #17 on: February 24, 2011, 03:11 PM »
If its a Koizumi framed TAP then the Serial No. could take some uncovering.
Another tell-tale sign of a 'Koizumi' frame is the chain stay positioning...
KOIZUMI
TANGE
StellaAtoiz
« Reply #18 on: February 24, 2011, 03:25 PM »
Cheers Glynn - will do :daumenhoch:
StellaAtoiz
« Reply #19 on: February 24, 2011, 04:43 PM »
David.
You certainly know you way around the rear end of a Burner :daumenhoch:
Thanks for the info - serial number exactly where you said it would be ;)
