976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 07:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP!!! - why is my crank arm stuck!!??
Author Topic: HELP!!! - why is my crank arm stuck!!??  (Read 3313 times)
StellaAtoiz
« on: March 30, 2011, 05:46 PM »
Gents.
I have removed the cap, I have removed the retaining nut......I have soaked it in WD40.......I have hit the fookin thing with a rubber mallet.........why won't my crank arm come off ??? :'(
Am I doing...or not doing something so obviously stupidly wrong? >:(
Thanks for your time :daumenhoch:
xGoose
Re: HELP!!! - why is my crank arm stuck!!??
« Reply #1 on: March 30, 2011, 06:04 PM »
Im not 100% sure but you might be able to get a special crank pulling tool (your lbs might have one) that would get that off no probs.
I know they they are available for new cranks but just not sure if they'd work on an os crank like that.
Look something like this,
http://www.google.com/images?hl=en&q=crank%20puller&rlz=1B3GGLL_enHK419HK419&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1280&bih=587
Good luck! ;)
Offline PHIPPSIO
« Reply #2 on: March 30, 2011, 06:08 PM »
Yeah you need an crank arm extraction tool. Think you can get them on ebay or chain reaction. Make sure you get the right size though there are a few that fit different size spindles.
« Reply #3 on: March 30, 2011, 06:10 PM »
Alloy (crank arm) to steel (BB spindle) fuses really easy after time and dampness
Not as bad as  the old alloy seatpost stuck in the steel frame ploy , due to less contact area   ;)
An extractor like Xgoose says would easy do the trick
http://cgi.ebay.co.uk/Icetoolz-Crank-Extractor-Tool-NEW-Suits-Splined-Square-/360294203643?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item53e33540fb#ht_500wt_922
« Last Edit: March 30, 2011, 06:12 PM by Hunterdubber »
StellaAtoiz
« Reply #4 on: March 30, 2011, 06:13 PM »
Many thanks guys - that's a great help :daumenhoch:
« Reply #5 on: March 30, 2011, 06:17 PM »
Yep, you need a crank puller Jase!
Fookin hell bud, you call us northern folk stupid..
StellaAtoiz
« Reply #6 on: March 30, 2011, 06:59 PM »
Spen.
That sounds like I might have to get my hands dirty :shocked:
When are you coming down south next??.......or can you send one of your natives down here to do it for me :coolsmiley:
« Last Edit: March 30, 2011, 07:14 PM by StellaAtoiz »
1mancity2
« Reply #7 on: March 30, 2011, 09:39 PM »
Just post it to me bud :daumenhoch:
sid1972
« Reply #8 on: March 30, 2011, 09:44 PM »
never used an extractor - just a nice peice of wood (used as a drive near to the nut end of the crank) and a wood mallet..
Works everytime - well so far anyway!
1mancity2
« Reply #9 on: March 30, 2011, 09:46 PM »
yeah Sid that works as well  :daumenhoch:
StellaAtoiz
« Reply #10 on: March 30, 2011, 09:48 PM »
Sid.
I was whacking the fcuk out of it with an 8lb sledge hammer against a piece of wood in the end and it was not moving an millimetre....I stopped as I thought I might damage the frame :D
« Reply #11 on: March 30, 2011, 09:57 PM »
Heat...Alloy expands quicker than steel. Boiling water then crank extractor or neandatholstick and piece of wood  :daumenhoch:
Hootski70
« Reply #12 on: March 30, 2011, 10:44 PM »
Do not hit it with stuff jase , use the proper tool for the job . Invest in a crank puller but take it easy as alloy threads strip soooo easy, wind it in all the way then put some tention on it and pop it on the radiator . If it won't budge sent it tup north and we will hit it with a proper northern monkey wrench . :laugh:
« Reply #13 on: March 31, 2011, 07:40 AM »
steel chisel and lump hamer works everytime....  damages the cranks mind... :-\
Offline SE MARK
« Reply #14 on: March 31, 2011, 10:02 AM »
Ive just brought a crank puller from Halfords for £9.99 . Needed to put an extension pole on the end of it though to tighten it more as i couldn't get enough force from the thing . Does work though and only a tenner.
sid1972
« Reply #15 on: March 31, 2011, 02:23 PM »
Use the right tool for the job - trouble is I can never find anything when I need to and I tend to use my knockommeter..
I often find that hitting it 'on' first works (taps - not extreme force), like tightening a stuck nut will haveten free it (I slight nip, not a full turn) , rather than trying to lossen it  etc - but what works for one  :-X
Offline Gary72
« Reply #16 on: March 31, 2011, 07:17 PM »
Your not far from me, I have a crank puller you can borrow. :daumenhoch:
