976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 04:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ripper brake setup help please.....
Author Topic: ripper brake setup help please.....  (Read 4786 times)
waza04
« on: March 31, 2011, 06:57 PM »
hi folks, need a wee bit of advise please..... building my ripper, and i'm trying to use a mx1000 on the rear with a self centering thing..
problem is, the mechanism for the self centering thing touches on the brake bridge and the rear down tubes, obviously the bridge is flat as opposed to the normal round one's, also what do you use instead of the half moon clamps on the flat  bridge
maybe i'm doing something wrong, or have i gotta convert the mx1000 to a normal spindle..
any help always appreciated.  cheers wayne.  :daumenhoch:
« Last Edit: March 31, 2011, 07:00 PM by waza04 »
simo27
Re: ripper brake setup help please.....
« Reply #1 on: March 31, 2011, 08:58 PM »
Hiya
Do you have a spacer to keep the self centre thing away from the frame?
simo
« Reply #2 on: March 31, 2011, 09:00 PM »
 ::) what he said
bmx xxx
« Reply #3 on: March 31, 2011, 09:01 PM »
cool fins of a skyway brake block,
look good as well.
i went this way with the mx1000, but ended up fitting a pitbull caliper.
better for riding.
gary  :daumenhoch:
waza04
« Reply #4 on: March 31, 2011, 09:30 PM »
Hiya
simo
no spacer mate, i take it that must be missing then, hence the reason theres a couple of washer on there! still not enough clearance though even with 3 washers on.  :yahoo_silent:
simo27
« Reply #5 on: March 31, 2011, 09:42 PM »
Spacer will be about 20mm or so
Offline Betty
« Reply #6 on: March 31, 2011, 09:52 PM »
Put the 2 half moon washers together on the caliper side to make one thick washer?
2 minutes turkish...
waza04
« Reply #7 on: March 31, 2011, 10:01 PM »
cheers chaps, i'll have ago 2moz now, as the mrs keeps shouting me, think she wants my stick.  :daumenhoch:
simo27
« Reply #8 on: March 31, 2011, 10:27 PM »
or to wash up
waza04
« Reply #9 on: April 01, 2011, 07:02 PM »
rite peeps, tried using spacers tonight and it kinda works, although it looks shite, but the pads are miles away from the rim, even with the calliper at the bottom of the bridge slot and blocks rite down..... is this normal, and how did peeps do it bitd! i wanna ride this, so needs to work properly.... please help meeeeeeeeeee.  :daumenhoch:
Offline Waxintaxin
« Reply #10 on: April 01, 2011, 08:19 PM »
Pics
but it could be a MX900 issue
Offline 58 delray
« Reply #11 on: April 01, 2011, 08:26 PM »
skyway/koolstop fins either side of the brake bridge  :daumenhoch:
you should just be able to see them in the pics
even then you have to have the wheel quite a way forward and the brake blocks all the way down
Offline SteveG
« Reply #12 on: April 01, 2011, 08:30 PM »
MX1000's arms are a bit short on a Ripper frame unless the wheel is well forward in the dropout. The self centering bit is a bit taller or gets quite close to the dropouts (can't remember now) so makes the problem a bit worse. The original spacers were the half round ones but they had special shaped holes in them
I swapped my self centering spindle for an earlier one and spaced the caliper so it just clears the frame. Allow for a bit of brake flex though.
waza04
« Reply #13 on: April 01, 2011, 09:13 PM »
cheers for all the advise and pic's chaps, it's all come clear now! i doubt i will  find any of those skyway cooling fins, so will try and knock something up on the lathe. thanks again................  :daumenhoch:
Offline 58 delray
« Reply #14 on: April 01, 2011, 09:20 PM »
you could always use penny washers from the local hardware store  :daumenhoch:
waza04
« Reply #15 on: April 01, 2011, 09:37 PM »
not really a big fan of washers mate ??? i'll make a little ally spacer at work.  :daumenhoch:
Offline 58 delray
« Reply #16 on: April 01, 2011, 09:44 PM »
neither am i but didn't know you could knock somthing up at work  :daumenhoch:
Offline Munnyella
« Reply #17 on: April 05, 2011, 07:58 AM »
I've got a pair of skyway ones you can have mate, i'll drop em in with the spokes if you like, need stripping though, I glass painted them red and then didn't use them.
waza04
« Reply #18 on: April 05, 2011, 06:22 PM »
cheers mark, your the man!  :daumenhoch:
