976301 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 03:26 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  se racing seatpost question....
Author Topic: se racing seatpost question....  (Read 2756 times)
waza04
« on: April 05, 2011, 08:05 PM »
hi peeps, i was looking through a few old adverts regarding the old rippers, and found one telling you about do's and dont's..... i noticed one had information regarding using the drop out savers and all that to protect them, and then noticed in small writing, it said do not use a fluted aluminium seat post,  :-\  does any1 know why this is? i know laybacks were a deffo no no, but thought a straight one would be ok. any help appreciated. cheers  :daumenhoch:
Offline 58 delray
Re: se racing seatpost question....
« Reply #1 on: April 05, 2011, 08:11 PM »
first off not sure if fluted posts came in 13/16ths but if they did i would imagine the reason would be that A) not enough surface area in the seat tube and B) ally to ally fusion  :daumenhoch:
waza04
« Reply #2 on: April 05, 2011, 08:27 PM »
cheers for that dude...... i had one turned down to 13/16th, better get some lube down there.  :shocked:
Offline HARORIDER
« Reply #3 on: April 05, 2011, 08:33 PM »
strange as the retro rippers come with just that :-\ thicker post though :daumenhoch:
« Reply #4 on: April 05, 2011, 09:20 PM »
It's Aluminium to cro-mo you get the fusion  ::)
or alu to alu as well ?  ???
Offline 58 delray
« Reply #5 on: April 05, 2011, 09:23 PM »
ally to ally as well
Offline rooski
  • Mons Veneris
« Reply #6 on: April 05, 2011, 09:32 PM »
If ally aint anodised it can react with the other part,causing seizing.
also if the two parts are a tight fit it can "pick up" on the other part,so as you try to pull/twist it apart it will get tighter and seize :(
i always use copper grease when installing ally parts,headsets,bbs etc :daumenhoch:
