976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 01:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  how do you date a gt by its serial number
Author Topic: how do you date a gt by its serial number  (Read 2220 times)
steve
« on: May 13, 2006, 08:20 PM »
-and what is M I ?
serial number -12925091
then under
M I
-CLUES
-rings on head tube
squared not angled top tube through seat tube gt 4130 on cap
-gt stamped on all 4 sides of rear drop outs
-18.5 inch top tube
-right - so its a us built one, as the number is on the drop outs
-so is it a jan 82
or a december 92??
« Last Edit: May 13, 2006, 10:45 PM by steve »
Moza
Re: how do you date a gt by its serial number
« Reply #1 on: May 14, 2006, 03:15 PM »
The top tube size indicates a standard model, my number was under the bottom bracket and had 84 in it. That seems to indicate an 1984 bike. I could be wrong but if your top tube is flat and not sloped im sure its before 1984, its just that all the GTs ive found on the net are like this before 84. Ive had the same trouble tracking my frame it seems its a standard 84 frame with pre 83 forks. Its in this resto section somewhere.
Offline stuntmaster
« Reply #2 on: May 14, 2006, 05:24 PM »
dec 92 beware tho as some gt `s weren`t made in usa and the serial number`s of them is totally different as had a perfomer that was like that
no1stuntmaster on instagram
steve
« Reply #3 on: May 14, 2006, 08:11 PM »
the yank site reckons
-serials on the bottm bracket, are jap made ones
-and numbers on the drops are us ones
-not that i makes a difference to me
-but i like the idea od it being early
-kind of feels early???
Offline aditup2004
« Reply #4 on: May 14, 2006, 08:40 PM »
Dec 92.
Is it the same as this;
If it is, this is a 92 also. I have 2 of the same year with similar frame no's.
Ad
steve
« Reply #5 on: May 14, 2006, 08:48 PM »
yup
-and this
dec 1992 mach I
-have you a spare set of forks?
-they are us made ones
 :10_2_12:
« Last Edit: May 14, 2006, 08:50 PM by steve »
steve
« Reply #6 on: August 22, 2006, 11:41 AM »
Dec 92.
Ad
by 1990 -he rear lower tube bends up and meets the other tube??
Offline Bananaman
  • Le Mans Man
« Reply #7 on: August 22, 2006, 12:00 PM »
