976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 05:12 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What's the best freewheel for a coaster Tuff
Author Topic: What's the best freewheel for a coaster Tuff  (Read 3492 times)
Stevo
« on: May 14, 2006, 07:56 AM »
Fellas,
Please recommend the best freewheel (and supplier) to run on this coaster tuff (Suntour). I didn't have a coaster BITD and didn't realise threaded freewheels are no use.  :-[
Also, if anyone knows where to I can find the nut/bolt for fixing the arm to the frame (Haro Master) – or the best alternative.
Re: What's the best freewheel for a coaster Tuff
« Reply #1 on: May 14, 2006, 10:15 AM »
so what are you after.
a cog to fit so you can run the coster.
or is it a freecoaster you mean.
greentoad
« Reply #2 on: May 14, 2006, 10:38 AM »
Hi
Hmmmmm, a green tuff, If you have no joy in getting what you are after and want to shift it let me know.
J.
retrorider.u.k
« Reply #3 on: May 14, 2006, 10:43 AM »
you need an a.c.s. freecoaster which means you will be able to run it as either a freewheel or coaster brake or a j.b freewheel adaptor (alans).freecoaster from biagio or skatepool  ;)
Stevo
« Reply #4 on: May 14, 2006, 03:01 PM »
Sorry for the confusion here fellas. I want to use the coaster brake and only need a sprocket to run the chain.  :)
I have another rear freewheel tuff if I want to change to to a non-coaster set-up, so I don't need the ACS or JB adaptor Retrorider recommended.
Its just that most sprockets I have seen are threaded and the Suntour coaster isn't (see pic). Maybe I am missing something really obvious here.
retrorider.u.k
« Reply #5 on: May 14, 2006, 03:47 PM »
you can use the a.c.s as a coaster anyway if you can't source a sprocket  ;)
« Reply #6 on: May 14, 2006, 03:53 PM »
i've got a spare sprocket for that if you need it.pm me and let me know.
jeff spicoli
« Reply #7 on: May 14, 2006, 05:05 PM »
Hi
J.
Stevo
« Reply #8 on: May 14, 2006, 08:15 PM »
Yes Jeff I know its funny. You post a pic your prized gear and a member thinks it's for sale. No harm in asking I suppose.
Spent ages hunting for green coaster tuff to go with the freewheel pair I bought from Skyway (re-issued type). Pity they are not the exact shade of green, but most folks won't notice.
The coaster tuff was made in the UK. I didn't know they made them in UK BITD, always thought they were imported from US.
Hopefully Dordymush is going to help me out with a sprocket. Cheers.
jeff spicoli
« Reply #9 on: May 14, 2006, 08:38 PM »
you know what I am in two minds to get some skyways with a coaster myself. 540 kickturns and 540 rollbacks were so easy even one handed but not on a freewheel well not yet.  ;) your green tuffs look the biz.
greentoad
« Reply #10 on: May 15, 2006, 11:56 AM »
Hi
Green Tuffs  -
J.
Stevo
« Reply #11 on: May 15, 2006, 07:37 PM »
Thanks to Dordymush for posting this pic showing exactly what I need. Another problem solved thanks to the members on here  :daumenhoch:
Should be able to do a 'Stupple'  once its fitted.  :)
« Last Edit: May 15, 2006, 07:41 PM by Stevo »
Offline billstup
« Reply #12 on: May 15, 2006, 11:04 PM »
I`ve never had one with that sort of cir-clip on it, usually it`s like a round ring, if you know what I mean  :daumenhoch:
« Reply #13 on: May 15, 2006, 11:07 PM »
i know bill i told him that but i've lost the other one.
