making dx all shiny like new
<< < (2/2)
markyp:
--- Quote from: BENDYCAT ELEVENTEEN on April 29, 2011, 01:16 PM ---what sort of finish are you looking for - a lacquer will seal it, but i don't know what type is the best for this !
--- End quote ---
i just want them to not look dull and used,more out of the box with a bit of a sheen.autosol is no good,it turns them black and takes of the top surface leaving them pitted
BENDYCAT ELEVENTEEN:
just give them a rub with that green washing up cloth - you know the sort you get on the other side of a sponge for doing the dishes
It will give a cleaner look and not put too much of a shine on it - it might ware out you fingertips  ;D
autosol will turn things black but you can wash off with hot soapy water
peek will do the same job but put more of a shine on it the harder you work it
wirewool will shine it up and clean it up - depend on grade and how hard you work it
wire brash will put lines on it and polish up in places
green scourer, spongehalf/green will clean it up and put a light shine depending on how hard you work it
cheers B  ;)
brettypeeps:
I gave mine a quick rub with some Duraglit wadpol then rinsed them with soap a water :daumenhoch:
MartyC:
There was a thread on one of the US sites that did a step by step re-finish of a pair of DX pedals to make them uber bling, there was a link on here but as the search function is not working I can't find it.  I think it was on Vintage but I'm not a member there so can't find it there either!
Found it...
http://www.vintagebmx.com/community/index.php'showtopic=4005471
you need to be a member to see the images I think  :daumenhoch:
markyp:
cheers marty youre a star :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
