976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 07:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Quick fix chrome repair advice
Author Topic: Quick fix chrome repair advice  (Read 2723 times)
Offline rick1970
« on: April 30, 2011, 08:09 PM »
Ok folks i know this should'nt be done to an o/s rider but till i can afford a full resto re chrome which then again is questionable ,in the mean time this is buggin me so i need advice heres a pic of my frame but as you can see the rear of top tube below gt stamp has issues
so im thinking spray chrome or a liquid chrome on that area only as a quick fix, any ideas or recomendations on products to deal with this,thanks in advance  :daumenhoch:
firebird4130
Re: Quick fix chrome repair advice
« Reply #1 on: April 30, 2011, 08:19 PM »
solder over then polish it?
Offline rick1970
« Reply #2 on: April 30, 2011, 08:31 PM »
blimey has that been done before not sure i'd know where to start  :-\
moochalargo
« Reply #3 on: April 30, 2011, 08:39 PM »
Ooooh cool idea!! Has it been tried n tested?
firebird4130
« Reply #4 on: April 30, 2011, 08:52 PM »
I've filled a couple of drilled holes in some chrome dropouts with solder and then sanded and polished you have to be careful not to burn the surrounding chrome so melt solder then stick it on, you could hardly see them after, it did dull a little iirc but maybe a bit of clear laquer over top would deal with that  :daumenhoch:
winnit93
« Reply #5 on: April 30, 2011, 09:40 PM »
is this the slowest build in history :LolLolLolLol:
Offline rick1970
« Reply #6 on: April 30, 2011, 09:59 PM »
  :LolLolLolLol: yep
Offline Betty
2 minutes turkish...
Offline rick1970
« Reply #8 on: April 30, 2011, 10:35 PM »
Due to the advice taken from rad members on how to restore  a bike ,nine years later im still at the frame and forks and decals stage  :LolLolLolLol:
Offline Betty
« Reply #9 on: April 30, 2011, 10:40 PM »
You're going to snub Lenny's tin foil method...  :yahoo_silent:
Offline rick1970
« Reply #10 on: April 30, 2011, 10:56 PM »
  No i just ran out of foil hence the little patch it worked a treat  :LolLolLolLol: next up is comp 3 remoulds with elastic bands  :daumenhoch:
Offline Betty
« Reply #11 on: May 01, 2011, 11:16 AM »
 :LolLolLolLol: :LolLolLolLol:
