976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 03:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cranks and Chainrings
Author Topic: Cranks and Chainrings  (Read 2529 times)
kenloen
« on: May 04, 2011, 11:41 AM »
tell me, does any chainring fit any crank? I have a Profile Racing 3 piece crank but no chain ring. I like the Tuf neck chainrings but am unsure it they fit (the ones without the spider). Also, how many teeth is good - there are loads avaiable 42,43 44 teeth?? being fitted to a 86 PK Ripper..
cheers Jason.
Re: Cranks and Chainrings
« Reply #1 on: May 04, 2011, 01:35 PM »
Yep, any one piece chainring will fit any one piece or cor-moly 3 piece (Redline/Profile/Terrycable, etc) crank however you may need to get a Top-Hat washer to make them fit a 19mm axle, the size of the washer will depend on the chainring as they can vary a little.
http://www.alansbmx.com/product_info.php?cPath=32_34&products_id=2343&osCsid=c189a54cbf1b797680c45c1d7f663a14
Marty  :daumenhoch:
« Reply #2 on: May 04, 2011, 01:45 PM »
Chainrings come in various sizes and most people prefer 44t
Spiders and complete chainrings can come with a 19-23.8mm hole in the centre. Most but not all Redline 3 piece cranks are 19mm but some are 20mm and a standard 1piece crank is 23.8mm. There are adapters to convert a 23.8mm chainwheel to 20mm or 19mm and these are the top hat washer
As for fitting chainrings to spiders they either have a 110mm or 130mm offset so choose the chainwheel to match your spider
Or choose the same make to be sure.  :daumenhoch:
« Last Edit: May 06, 2011, 03:32 PM by brettypeeps »
kenloen
« Reply #3 on: May 04, 2011, 02:19 PM »
Ah, I know my crank axle is 19mm because I was advised on what BB to buy recently. So if I buy a 1 piece 4 bar chainring I will also need a 22-19mm tophat.. got it.. many thanks..
will hopefully have pics up soon..
Offline john4130
« Reply #4 on: May 04, 2011, 05:48 PM »
it wont be a 22-19 tophat  you'll need it'll most likely be a 15/16"-19mm. opc are 15/16" and most old chainrings came in this size to fit them. it wont be hard to find a tophat washer in this size tho.
HEYWOOD BMX
« Reply #5 on: May 04, 2011, 06:38 PM »
 :) Most oldschool spiders/chainrings have a 23.8mm centrehole-to fit a Tufneck onto Profiles you`ll prob need this size down to 19mm tophat washer:)
The VW Doc
« Reply #6 on: May 05, 2011, 08:45 PM »
Sorry to hi-jack a little, bit I am looking for a spec for the nuts & bolts to hold the chainring to the spider (as I am wanting to replace them with stainless steel ones) and not having any to go on is making it a little difficult
Can anyone assist please?
« Reply #7 on: May 06, 2011, 03:27 PM »
You need single chainring or outer chainring bolts like these:
Usually 6mm thread depth  :daumenhoch:
The VW Doc
« Reply #8 on: May 06, 2011, 03:32 PM »
Cheers Marty - Why are they externally threaded but still hollow? Weight ,or does soemthing screw into them?
I haven't got the spider yet, so I am waiting to see how that fits, but the chainring is not threaded
(Sorry for the Newbie questions)
« Reply #9 on: May 06, 2011, 03:41 PM »
No worries, they will have another section to screw into like these ones...
They are generally hollow to save weight  ;)
The VW Doc
« Reply #10 on: May 06, 2011, 08:06 PM »
Ah ha! makes sense! Thanks mate :)
