976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 07:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Benders - any others in here? (tips and tricks)
Author Topic: Benders - any others in here? (tips and tricks)  (Read 2042 times)
punkdSICO
« on: May 15, 2011, 07:45 PM »
Wooh!!  Finally managed to get some levers Im happy with:
The below pic shows the angle I have added.  Originally, the lever would have been straight down but I have pushed it back about 15 degrees.
This pic shows how not to do it..!!  I did the first lever using two spanners with no protection:
This is my second attemd, with only minimal damage.  Again, I could have done better than this with a little hindsight.
Ohers have mentioned using a blow torch, but I dont have one.  Also, not sure how much paint damage this would do..
Now I just need to decide if I want to put my old school Dia Compes back on the bike, after a little bending.  Eitherway, ill replace the trashed lever with a new one (my local store has them on offer for sub-£10)
My tips for safe bending:
  • remove the lever from the brake housing
  • put something metal inbetween the levers two arms that the bolt goes through.  I did not do this for the first lever and the vice colapsed the arms slightly.  I then had the task of getting them back straight again..
  • Use a vice and protect any metal on metal contact
  • Have the lever poking out of the vice with the bend point on the edge of the vice
  • Putting a bit of wood between the lever and your hammer, hit the wood frickin hard.  Then it it even frickin harder!!
  • Start off by practicing with a lever you dont mind spoiling. With practice, you can bend with little/no paint damage.
ta,
Paul
Re: Benders - any others in here? (tips and tricks)
« Reply #1 on: May 15, 2011, 08:13 PM »
Currently Hunterdubber is the biggest Bender on here  :daumenhoch:
waza04
« Reply #2 on: May 15, 2011, 08:27 PM »
nice bit of bending........... :(  would have just dropped some tech4's on!  :daumenhoch:
punkdSICO
« Reply #3 on: May 15, 2011, 08:50 PM »
Yeah, someone else mentioned Tech4s but, they only bend in the one direction and dont follow the bars back.  I know that is hard to explain but, althought the Dirty Harries are bent-t'feck, until I whacked them with a hammer, they were sticking out into space and nowhere near where I wanted them to be..
ta,
Paul
firebird4130
« Reply #4 on: May 15, 2011, 08:57 PM »
I usually wrap a cloth round the lever or a bit of electrical tape  stick a seatpost over it and bend away
punkdSICO
« Reply #5 on: May 15, 2011, 09:13 PM »
..Like the idea of that.  And sounds a lot easier to avoid paint damabe..
I presume you have the other end in a vice??
Good tip..
Paul
Offline Betty
« Reply #6 on: May 15, 2011, 10:23 PM »
You're asking that on ere.... did make me chuckle...  ;D
2 minutes turkish...
firebird4130
« Reply #7 on: May 16, 2011, 01:34 AM »
Good tip..
Paul
no vice required, just have your lever fitted to the bars as normal, and bend with seatpost  :daumenhoch:
