976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 11:34 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff 2 unbuckle?
Author Topic: Tuff 2 unbuckle?  (Read 2296 times)
ukoldschool
Tuff 2 unbuckle?
« on: May 25, 2011, 01:51 PM »
Hi all,
Ive neglected my streetbeat and left it languishing in the shed.... since getting it out ive noticed a definate buckle on oen fo the Tuffs... of course back in the day the freezer trick was said to work but I never needed to try it back then, so wuestion is - does it work? if it doesnt, is there anything I can do to bring this wheel back? its a grey tuff so finding a replacement isnt going to be easy I guess?
cheers!
Offline Dannywhac
  • return of the whac
Re: Tuff 2 unbuckle?
« Reply #1 on: May 25, 2011, 03:00 PM »
Freezer trick's one of them urban myths - doesn't work.  Unless you want to piss the missus off.....
Read somewhere over at the bmxmuseum that a bloke had made a circular press, lightly heated the tuff and gradually cooled it and it worked (although if it's well buckled you're screwed) as most forms of plastic/nylon has a 'memory' from when it was moulded.....
« Reply #2 on: May 26, 2011, 12:29 PM »
pic please  ;)
Offline Dannywhac
« Reply #3 on: May 26, 2011, 01:05 PM »
Here's the thread about the press:
http://bmxmuseum.com/forums/viewtopic.php?id=58417
Although can't find (due to the 'Google Search' nature of BM) the thread where someone said about the heating - the above relies on time and plaggy memory :)
ukoldschool
« Reply #4 on: May 26, 2011, 02:34 PM »
thanks for the links fellas :) im liking the sound of 'if you cant be bothered to take the wheel out jam a block of wood in the frame' ;)
will try and get pics this weekend of a 'before' nature and see how it goes...
Offline oldtired
  • Dirty Old Man
« Reply #5 on: May 26, 2011, 05:06 PM »
have used laggy bands in the past like this,  one from each side means you can centre the wheel between forks/stays leave sat for a few days , can only do one bend at a time ,  wooden doughnut press is the best method for a wobbler though  :daumenhoch:
« Last Edit: May 28, 2011, 10:06 AM by oldtired »
ukoldschool
« Reply #6 on: May 27, 2011, 10:16 AM »
oooh thats a good idea..... hmmmmmm  :D
Offline Dannywhac
« Reply #7 on: May 27, 2011, 10:18 AM »
Yeah  that pee's on the 'wedge a block of wood in there' method  :daumenhoch:
