976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 10:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BB info needed - please look and work out !
Author Topic: BB info needed - please look and work out !  (Read 1736 times)
« on: May 29, 2011, 10:35 PM »
while i was also at the carboot today i bought this
BB - has Cr-Mo CV-170 84 -C ? Is that a year or just parts number ?
does any one know who's make it is and what year it is from ?
i tried putting the cups into my 83' goose frame - one side fitted nice but the other side is about 1mm all round small ? ? can't work out why ? any one ?
also from the carboot today was a 25.4 double bolt Fishbone seat clamp
and a SunTour 17t freewheel
all this lot for £4 sweet   >:D
cheers B  :D
« Last Edit: May 29, 2011, 11:09 PM by BENDYCAT ELEVENTEEN »
Re: BB info needed - please look and work out !
« Reply #1 on: May 30, 2011, 01:12 PM »
cheers mate for the pic  ;)
do the cups look right for a tioga set ? the rest seem to match or so, but the inside cup edge is not the same - and it still doesn't explain why one of the cups is out by a mill all around ?
cheers B  ;)
monkian
« Reply #2 on: May 30, 2011, 01:26 PM »
It's one of these B. Got one here all exactly the same except my axle is stamped 83-C & has a little Tange logo (could be a year thing) 8)
Tange also released it in their own branded packaging. Got another CV-170 Axle from a CK-170DX BB Set with no logo or date stamp.
Hope that helps :)
« Last Edit: May 30, 2011, 01:32 PM by monkian »
« Reply #3 on: May 30, 2011, 01:45 PM »
dose mate  ;)
but what should i put around the smaller cup to make it fit better - electric tape or ?
bmx xxx
« Reply #4 on: May 30, 2011, 02:13 PM »
i had that bottom bracket on my suntour vx cranks
monkian
« Reply #5 on: May 30, 2011, 04:41 PM »
dose mate  ;)
Is it definitely the cup? Did you try them both in the same side?
I'd maybe make a metal shim - Coke can or some of that foil ribbon used for Pro Class Rims ;)
