976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 05:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Old skool Brakes - good or not?
Author Topic: Old skool Brakes - good or not?  (Read 1855 times)
The VW Doc
« on: June 03, 2011, 02:34 PM »
Having virtuallly finished my 2 bike builds (a DP Firebird Mk2 and a Mk1 Raleigh Burner) i took them for a little test ride yesterday.
I remember (20-25 years ago now) that I used to be able to lock the back wheel up of my bikes when riding, but now the brakes seem a little feeble.
I know I am now much heavier than I was, but they do seem quite poor. The Firebird has MX levers & brakes, the Burned has all original Weinmann brakes.
The brakes on both bikes are similar in performance - new brake blocks (both bikes have different types fitted) fitted fresh from the box with no sanding/roughing up the surface. Should i have done this? And all the wheels are alloy rims. No I haven't polished the rims.
Maybe I ought to meths wipe the rims (to de-grease them) in case they have got contaminated? Although to my finger, they dont feel greasy/oily
Or are they just generally not good compared to the brakes on newer bikes?
Offline TELLIS302000
Re: Old skool Brakes - good or not?
« Reply #1 on: June 03, 2011, 03:16 PM »
They are obviously not as good as todays standard of brakes.
Let them bed in a bit the re adjust them.
If you are going to wipe the rims etc use something like brake and clutch cleaner...can be bought in an aerosol.
Antony
« Reply #2 on: June 03, 2011, 03:23 PM »
Old brakes are rubbish but look the Mutts.
I use new school blocks when I ride and they work well with Dia-compe 880's
Clear brake blocks are meant to work well :daumenhoch: but I use the new Skyway blocks and the are fine for me :4_17_5:
sid1972
« Reply #3 on: June 03, 2011, 03:26 PM »
I always thought 1000's were awesome, depends what your doing?
got to be better than wedging your foot in the forks..  :idiot2:
The VW Doc
« Reply #4 on: June 03, 2011, 03:28 PM »
Cheers guys - i will give them time to bed in (and not try any emergency stops!)
I may wipe the rims down as well (and roughen up the brake pad surfaces as well - every little helps  :)
The VW Doc
« Reply #5 on: June 03, 2011, 03:30 PM »
Definately! I dont get how kids ride bikes nower days with no brakes?? - God I must be getting old!  :-[
« Reply #6 on: June 06, 2011, 12:30 AM »
get some clear new school pads mucka.
they'll stop ya  :daumenhoch:
Offline glenboy
« Reply #7 on: June 06, 2011, 01:04 AM »
yes as above the tech has moved on and we are generally a bit heavier than back in the day give darren K.A.P. off here a pm he has some new school pads with os brakes and they really stop his are yellow sort of clear pads similar to  skyway
The VW Doc
« Reply #8 on: June 06, 2011, 12:26 PM »
Cheers glenboy - I have PM'd Darren K.A.P to see what he has
Dordymush - any "clear new school pads" in particular? (Or is there really only one make??
