976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 02:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose / Minigoose crank size question
Author Topic: Mongoose / Minigoose crank size question  (Read 3764 times)
Offline johnjo74
« on: June 10, 2011, 03:31 PM »
I'm thinking about putting a 'wanted' up for a Mongoose stamped opc .
 Just wondered if anyone can tell me what's the shortest length they came in ? I think I'll need something around 150 .
Did the Minigoose have one fitted ?
« Last Edit: June 10, 2011, 10:12 PM by johnjo74 »
Daletsunami
Re: Mongoose cranks
« Reply #1 on: June 10, 2011, 03:55 PM »
I think 165 is the smallest you will get  8)
1mancity2
Re: Mongoose cranks
« Reply #2 on: June 10, 2011, 04:35 PM »
As Dale says 165 is the most common size, I have one if your intrested  :daumenhoch:
Offline johnjo74
Re: Mongoose cranks
« Reply #3 on: June 10, 2011, 06:53 PM »
Cheers Dale ,
 I thought that the Minigoose would have had a smaller sized crank , maybe they weren't stamped ?
Offline johnjo74
Re: Mongoose cranks
« Reply #4 on: June 10, 2011, 06:57 PM »
Thanks for the offer  8) I will need something shorter though .
Offline johnjo74
Re: Mongoose / Minigoose crank size question
« Reply #5 on: June 12, 2011, 06:47 AM »
Anyone have any 'actual' info on this ?
Offline diesel
« Reply #6 on: June 12, 2011, 08:56 AM »
Offline johnjo74
« Reply #7 on: June 12, 2011, 11:15 AM »
This might help you decide:
http://www.radbmx.co.uk/forum/index.php'topic=124219.0
Thanks mate , that's quite useful regarding size  8)
What I wouldn't mind finding out though,  is whether or not there is a stamped Mongoose opc smaller than a 165 ?
I found a picture on the Museum of a 1984 Minigoose that has one on , but no mention of length .
http://bmxmuseum.com/bikes/mongoose/48125
I would have thought  it's a shorter one as the frames are smaller ??
Offline kdw712
« Reply #8 on: June 12, 2011, 11:37 AM »
think the stock mini's had a 5.5" cranks which is about 140mm
looking at this 1984 test spec its says minigoose had that
http://img.photobucket.com/albums/v603/kdw712/mongoose%20scans/p76.jpg
full thing is here
http://www.kdw712.pwp.blueyonder.co.uk/scans.html
also check the 78, 79 - 80, 81  catalogues on Vintage mongoose as they confirm it too
happy hunting  ;)
cheers Kev
Offline johnjo74
« Reply #9 on: June 12, 2011, 08:59 PM »
Thanks for that Kev  8)
 Probably a long shot anyway , but I didn't want to start looking for something that never existed in the first place  :)
Offline kdw712
« Reply #10 on: June 12, 2011, 09:04 PM »
cheers Kev
