976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 10:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Problem fitting freewheel to hub
Author Topic: Problem fitting freewheel to hub  (Read 3896 times)
Offline Jamroll
« on: June 15, 2011, 02:55 PM »
So, finally got around to finnishing my 1st wheel build, fookin ages that took  :shocked:
Now I've got a 16t Shimano Freel wheel and I'm trying to fit on a bullseye hub, the freewheel is going onto the hub about halfway and then is getting very very stiff, I've tried a little WD40 to help the bugger along but its not getting any easier, really don't want to force it incase i damage the hub. The thread pattern appears the same  ??? Any thoughts  :-\
Al  :daumenhoch:
1mancity2
Re: Problem fitting freewheel to hub
« Reply #1 on: June 15, 2011, 03:11 PM »
Sounds like muck in the threads, try spraying wd on the hub and using a wirebrush to clean the thread and then wd and a toothbrush on the inside of the freewheel.  :daumenhoch:
Offline Jamroll
« Reply #2 on: June 15, 2011, 03:20 PM »
I'd be surprised if it were that, both free wheel & hubs are brand new out the box, anyho its raining and I've got nowt else to do so will crack on with that  :daumenhoch:
1mancity2
« Reply #3 on: June 15, 2011, 03:52 PM »
You putting any anti sieze grease on?
Offline Jamroll
« Reply #4 on: June 15, 2011, 03:58 PM »
Slapped a little on, didn't want to cake it though...
« Reply #5 on: June 15, 2011, 05:23 PM »
Yep, you should always grease the threads before unstalling a freewheel anyway so you can get the fooka back off. Try winding it 3 turns forward, 1 back with loads of grease and it should go on no probs. Or wait till the bike's finished and pedal it on!
Offline Jamroll
« Reply #6 on: June 15, 2011, 06:53 PM »
Think I may have been miss sold a freewheel, shimano yes but suitable for bmx..not so sure Model # SF-MX 30
Offline Betty
« Reply #7 on: June 15, 2011, 06:59 PM »
Shimano mx 30 is for bmx...  :daumenhoch:
2 minutes turkish...
Offline Jamroll
« Reply #8 on: June 16, 2011, 09:14 AM »
so why wont the fookin thing fit  :2gunsfiring_v1: ???
Offline 58 delray
« Reply #9 on: June 16, 2011, 03:43 PM »
do you have any other freewheels you can try, so as to determine where the problem lies?
Offline Jamroll
« Reply #10 on: June 16, 2011, 03:56 PM »
Just bought adicta freewheel on the bay, should be with me Saturday for that very reason mate...It's doing my head in to be honest, it going on far enough that i need a freewheel remover to get the bloody thing off but not far on that its clear of the hub.
This should be a fooking doodle, I tell ya this bike just does not want to be built  :2gunsfiring_v1: ;D
« Reply #11 on: June 16, 2011, 04:27 PM »
if it's for riding i'd use the Dicta anyways........shimano ones are w@nk  :daumenhoch:
« Reply #12 on: June 17, 2011, 12:26 AM »
Had this before on a set up - seem to go on for about quarter then started to get stiff  ???
now if you look at the threads on each item you might find that they arte not the same in shape - this means that the freewheel thread is VVVVVVV and the hub thread is vvvvvvvv - now it may be the same size but if you look at it like joining teeth they don't fit neat - so as it goes on, the more it throws the matching teeth out of shape, and making it tighter to put on
so the best way i can think of is the get a old hub and put on the new freewheel and tighen it up (with undoing it every 3 turns and back up again ) this might cut the thread/teeth better for the bulleyes hub - if not try a old freewheel that works well on a old hub and try to put that on the Bullseye hub to soften the teeth/thread
hope it helps mate
cheers B  ;)
